Thermodynamics- piston cylinder- 2nd law of thermodyamics
The discussion centers on understanding the nature of a piston-cylinder process in thermodynamics, specifically whether it is a constant pressure or polytropic process. Participants clarify that the scenario involves a constant pressure process, as indicated by the balance of forces on the piston, which remains unchanged despite volume increases. The p-V curve for this process is a straight line parallel to the x-axis, contrasting with the pVγ curve associated with adiabatic processes. The importance of recognizing the conditions of the system, such as the negligible weight of the piston and the equal forces acting on it, is emphasized. Ultimately, the discussion highlights the significance of analyzing force balances to determine the type of thermodynamic process occurring.
student23
( part a only I don't understand how you know from this question that it is a constant pressure process.
I thought it is a polytropic process. So it will have a pVγ curve. I was drawing a pV curve.
The answer is a straight line parallel to x- axis.
My question: How do I know from looking at the question what kind of graph it will be and what process it will be? constant pressure, constant volume or etc?
Thanks,
Hi student. Consider a force balance on the piston. Note that they say the piston has negligible weight. How would the force up correlate to the force down as the piston moves within the cylinder and before it hits a step (ie: while it is sliding)?
Following on Q_Goest: If you do a free body diagram on the cylinder just before it starts to move, the force on top of the cylinder is 800 N and the force on the bottom of the cylinder is also 800 N so the pressure are also equal. Now let the volume increase just a little. A free body diagram shows that the forces (and pressures) stay the same. Let the volume increase a little more, same result, a free body diagram shows the forces (and pressures) above and below the cylinder are still 800 N. Since the pressures don't change, the cylinder must be under going a constant pressure process.
Thanks,
The p-V curve will not be pVγ. That would be the case for an adiabatic (isentropic) process. You're adding heat Q. And yes, p stays constant as RTW69 points out. It's always atmospheric pressure.
