Thermodynamics problem - internal energy of a saturated steam?
The discussion centers on determining the internal energy at state 1 for saturated steam. It clarifies that internal energy for saturated steam should be considered as U_vap only, not the sum of U_vap and U_liq, despite the presence of both phases. The user successfully calculated pressure, temperature, and specific volume values for state 1, as well as the work done by the steam. However, they are struggling with the total heat transfer and the relationship between internal energy and work. The consensus is that "saturated steam" refers solely to the vapor phase in thermodynamic calculations.
theBEAST
For those who are not interested in reading through the different values I get for each stage then please answer this question:
What is the internal energy at state 1? When water is a saturated steam... Is it U_vap + U_liq since saturated steam has both liquid and gas phases in it? Or is it just U_vap?
If you are confused it may be worthwhile to see what each state is in the following text I wrote:
Thanks!
In this question there are 3 states. The question also has three parts to it.
First Part:
Find the initial pressure, temperature and specific volume values at state 1 from the steam tables and appendices. I ended up getting these values (these are correct as I have checked the answer key):
P1 = 500kPa
T1 = 425.65K
v(specific volume)1 = 0.37297
Second Part:
Find the work done by the steam. I calculated this and got the same answer as the answer key which is:
W(state 1->3) = 232.3 kJ/kg Note they want the answer in specific energy
Third Part:
This is where I am stuck. This one asks for the total heat transferred to the steam.
I know that:
H = ΔU + W
Where ΔU is the change in internal energy from state 1 to state 3. My main problem concerns solving for the internal energy in state 1 using the steam tables. First off state 1 is saturated steam, so from the Thermodynamics tables I get several internal energy values. I get U_vap, U_liq and U_evap. From what I have learned a saturated steam includes water in both liquid and gas phases? Thus U(state 1) = U_vap + U_liq...?
This does not work and the answer suggests that U(state 1) = U_vap only.
Thanks!
First Part:
P1 = 500kPa
T1 = 425.65K
Second Part:
Third Part:
I know that:
H = ΔU + W
I can not see the image. Can you re-upload it please ? Also absolute internal energy of the system is undefined. (Think why ?)
Dear beast,
The term "saturated steam" refers only to the vapor.
Chet
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
