Calculating Final Temperature and Ice Remaining in a Thermodynamics Problem
  • Thread starter Thread starter physicsnnewbie
    Thermodynamics
The discussion revolves around calculating the final temperature and remaining ice after adding a 45g ice cube at 0ºC to 240mL of water at 10.5ºC. The initial calculations led to an incorrect negative temperature, prompting a reevaluation using calories instead of joules for simplicity. The heat available from the water is calculated as 2520 calories, allowing for the melting of 31.5g of ice, leaving 13.5g of ice remaining. The final temperature is determined to be 0ºC, as the water temperature stabilizes at the melting point of ice. The use of calories is noted to be more straightforward for this thermodynamics problem.
physicsnnewbie
You take a jug of water from the refrigerator, and pour 240mL of it into a glass. The temperature of the beverage is 10.5ºC. You then add one 45g ice cube at 0ºC.
Determine the final temperature and the amount of ice remaining if any.
I've tried to work it out below, but my I must've made an error because the temperature has to be between 0 and 10.5. Where have I gone wrong?
4.184*240(x-10.5) = -[45*333+4.184*45(x-0)]
1004.16x - 10543.68 = -[29970+376.56x]
1004.16x - 10543.68 = -29970-376.56x
1,380.72x - 10543.68 = -29970
1,380.72x = -19,426.32
x = -19,426.32/1,380.72
x = -14.06970276
thanks
It is most convenient to work in calories rather than converting to joules.
1. First find the amount of heat available in the water.
240g * 10.5 C = 2520 cal
2. find the amoutn of ice this will melt.
Heat of fusion is 80 cal/g.
Amount of melt = 2520 cal / (80 cal/g) = 31.5 g
3. Find remaining ice
45g - 31.5g = 13.5g
4. Since we've pulled water temp to 0C, and there's ice remaining at 0C, final temp=0C
thanks marcusl :)
I'm not all that sure about that. I haven't done a problem in calories before.
It's a small difference, doesn't really matter either way. 4.18 Joules of heat energy raise the temperature of 1 gram of water by 1 degree C. By definition, one calorie of heat energy raises the temperature of 1 gram of water by 1 degree C. The calorie unit is a little simpler or more direct in this problem. End result is the same :smile:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
