Calculating Work Done in a Closed Piston Cylinder Device with V^1.2 = Constant
  • Thread starter Thread starter junglep
    Thermodynamics
The discussion revolves around calculating the work done during the expansion of air in a closed piston cylinder, where the process follows the equation PV^1.2 = constant. Participants clarify that this represents an adiabatic process, indicating no heat transfer occurs. The work done can be calculated using the formula W = -P(Vf - Vi), but the unique exponent of 1.2 raises questions about its implications. There is a request for further explanation on handling the V^1.2 relationship in the context of the work calculation. Overall, the thread seeks assistance in understanding the specific characteristics of this adiabatic process and the associated calculations.
junglep
hey guys got this question that i have been stuck on for a while.
air is expanded from 1M Pa at 327 degrees celcius to 200kPa in a closed piston cylinder device. for the process PV^1.2 = constant. calculate the work done during this process
any help will be welcomed
cheers
temperature constant? work done= -pV ?
if [P(V^1.2) = constant] this is an adibatic process which means that there is no heat added or taken away.
I have not encountered something like V^1.2 before. Is that right? If so can someone enlighten me about it?
