This is incredibly hard for Grade 12 homework
In summary, the conversation discusses a challenging physics homework problem involving three masses connected by four strings with unknown tensions and angles. The problem is set up with non-linear equations and the need to solve for multiple variables. The participants suggest using numerical methods and creating a program to solve the problem. The conversation also briefly touches on a separate question about resistance in a bent wire.
Catalyst
Incredibly hard Physics homework!
Alright, so here's the problem:
Three known masses are connected together by four pieces of ideal string of known length. Determine the tensions in the strings and the unknown angles, given any value for the length of the strings and the weights.
http://img122.exs.cx/img122/6239/75-physicsproblem.jpg
So far, I've been able to pull this information from the question:
0 degrees < {|A1|, |A2|, |A3|, |A4|} < 90 degrees
The direction that the angles will go will depend on whether the values of the angles are positive or negative.
T1 cos A1 = T2 cos A2 (1)
T2 cos A2 = T3 cos A3 (2)
T3 cos A3 = T4 cos A4 (3)
T1 sin A1 - T2 sin A2 = m1g (4)
T2 sin A2 - T3 sin A3 = m2g (5)
T3 sin A3 - T4 sin A4 = m3g (6)
l1 cos A1 + l2 cos A2 + l3 cos A3 + l4 cos A4 = L (length of top bar) (7)
l1 sin A1 + l2 sin A2 + l3 sin A3 +l4 sin A4 = 0 (8)
Given: l1, l2, l3, l4, L, m1, m2, m3
Find: T1, T2, T3, T4, A1, A2, A3, A4
How does one go about solving these non-linear equations?
I've solved this for 1 mass and halfway done solving this for 2 masses. Solving this for 3 masses is much harder though. Can anyone please help?
Looks tough. It's quite possible for anyone of the four strings to have zero tension in it, and the weights would then all hang directly under one or other of the support points - for example if:
[itex]L1 > \sqrt{(L2 + L3 + L4)^2 + 1}[/itex]
then all the weights would hang directly under the right hand support and the L1 string would hang slack.
I would solve this problem with numerical methods - a computer program that initially guesses angles, then calculates the force on each mass, based on the guess, and moves a weight to the right or left if the forces aren't in balance. Repeated iterations of the calculation would bring the out of balance forces arbitrarily close to zero, at which point the solution could be printed. A spreadsheet - e.g. an Excel spreadsheet could do this quite easily.
But I guess that's not the kind of solution you're looking for?
(I'm working with Catalyst on this problem; a group project)
This is the kind of solution we're looking for. We were told to create a program to solve this problem. Hmmm, I think I get what you mean.
OK. I would start by working out the Cartesian coordinates (x and y) for each mass.
If you have the left hand support as the origin (0, 0) and x increasing to the right, and y increasing vertically downwards (I know this seems backwards, but it stops the y values from all being negative), then m1 is at (x1, y1) where
x1 = L1 cos (theta1) and
y1 is L1 sin(theta1)
now for m2 you get
x2 = x1 + L2 cos(theta2)
y2 = y1 + L2 sin(theta2)
and so on...
By the way, for consistency in labelling the angles, theta4 in your diagram would have a negative value.
If you want some more hints, show me what you've worked out so far. :smile:
please help!
I can't solve this problem!
1. A uniform wire has a resistance of 18 ohm. It is bent to the shape of an equilateral triangle. What is the effective resistance between any two corners of the triangle?
Resistance Formula
Aratnaus. I believe you should have started a new thread, but since we are here ...
Effectively what you form with the equilateral triangle is three 6 ohm resistors, 18 ohms divided into thirds, so the resistance across any two points would be equivalent to a 6 ohm resistor paralleled with a 12 ohm resistor. You can see what I mean if you sketch the triangle and label each side 6 ohms. The basic formula for the total resistance of two parallel resistors is R1 times R2, divided by R1 plus R2.
Rt = (R1 x R2) / (R1 + R2). You can figure it from this point.
Rt = R1 x R2 / R1 + R2. You can figure it from this point.
Nicely done, CeeAnne. :)
(I'd've put parentheses around the (R1 + R2), but I'm picky that way.)
Thank you, Diane
Thank you, Diane. I did as you suggested.
1. Why is this homework so difficult for a Grade 12 level?
The difficulty level of homework assignments varies depending on the subject and the level of education. Grade 12 is typically the final year of high school, so the curriculum is designed to challenge students and prepare them for higher education. The concepts and skills being taught in this homework may be more complex and require a deeper understanding, thus making it more difficult.
2. How can I manage my time effectively to complete this homework?
Time management is essential for completing any task, including homework. It is important to prioritize your tasks and allocate enough time for each one. Break down the homework into smaller, more manageable chunks and work on them consistently. Avoid procrastination and distractions to stay focused and on track.
3. What resources can I use to help me understand this homework better?
There are various resources available to help with understanding difficult homework. You can consult with your teacher for clarification, join study groups with classmates, or use online resources such as textbooks, videos, and practice problems. It is also helpful to take notes and review them regularly to reinforce your understanding.
4. Is it okay to ask for help with this homework?
Yes, it is absolutely okay to ask for help with your homework. It is better to seek clarification and understanding from your teacher or peers rather than struggling to complete the assignment on your own. Asking for help shows that you are actively trying to learn and improve, and it can also help you build strong relationships with your teachers and classmates.
5. How can I stay motivated to complete this difficult homework?
Staying motivated can be challenging, especially when facing a difficult task like this homework. It is important to remind yourself of the purpose and importance of the assignment. Set small goals and reward yourself when you achieve them. Take breaks when needed, but make sure to come back to the task and complete it. Lastly, remember that hard work pays off, and successfully completing this homework will bring a sense of accomplishment and pride.
  • Precalculus Mathematics Homework Help
