Three Digital Clocks at Different Speeds
  • Thread starter Thread starter d-rock
    Clocks Digital
The problem involves three digital clocks, A, B, and C, which run at different rates and have non-simultaneous zero readings. Participants are tasked with determining the time differences between events on these clocks based on given simultaneous readings.
  • Participants discuss the use of ratios to relate the time intervals between the clocks. There is an attempt to understand how to apply these ratios to different parts of the problem. Questions arise regarding the interpretation of the clock intervals and how to approach parts of the problem without clear equations.
Some participants have found a productive direction by identifying the use of ratios to solve the problem. There is acknowledgment of the logic involved in the calculations, but uncertainty remains about how to proceed with all parts of the question. Guidance has been offered regarding the application of ratios, though not all aspects are resolved.
The original poster expresses a lack of familiarity with physics concepts and is under time constraints, needing to complete the problem by the next day. There is mention of limited prior knowledge and difficulty in reaching the instructor for help.
d-rock
Three digital clocks A, B, and C run at different rates and do not have simultaneous readings of zero. Figure 1-6 shows simultaneous readings on pairs of the clocks for four occasions:
___________312_________________512__ Clock A
___25______125_______200_______290__ Clock B
___92________________142____________ Clock C
For example, at the earliest occasion, B reads 25 s and C reads 92 s. If two events are 600 s apart on Clock A, how far apart are they on (A) clock B and (B) clock C? (C) When clock A reads 400 s, what does clock B read? (D) When clock C reads 15 s, what does clock B read? (Assume negative readings for prezero times.)
Unsure other than possibly a bunch of ratios?
Okay, on the little line chart I made above, any spot where the numbers are right on top/below each other is a point where sumultaneous readings are. At the first event, Clock B is at 25 seconds while Clock C is at 92 seconds, and so on.
Since the chart was somewhat easy to read, I added up the time between 312 and 512 on Clock A, and the time between 125 and 290 on Clock B:
(A) Therefore, for on Clock A there is a space of 200 seconds while Clock B has 165 seconds. For Clock A to go 600 seconds, I multiplied the space by 3, and thus did the same to Clock B's space since they are the simultaneous, thus getting a time of 495 seconds on Clock B. The answer in the book says this is correct.
The problem I have is that I have no absolute clue on what to do or what equations to use, as I obviously cannot use the above method for part B of the question.
I'm in a college-level Physics course in my 12th grade year of High School. I've no real Physics knowledge although I have taken one part of Calculus. We have not been tought much yet but the teacher allows us to call him if we need help. I cannot reach him however and so I'm pretty much stuck.
Is there any direction that someone can at least point me in, because this is already quite confusing? I'm assuming I need some ratios or something but I cannot put it together.
This is due tomorrow and I've only had today to do it. I have other problems to do too but this is the only tough one so far.
d d-rock,
is the line the clock interval ?
Hey, you got it right in the first part, this is really all about ratios:
What you did there is basically: (interval B/interval A) * 600 = 495
logically, all you have to do in (b) is: (interval C/interval B) * 495 =...
This is more about logic than actual physics (except when it comes to relativity principles); good luck!
Yeah I went into school early and was figuring out the ratio. I finally understood it so yeah, it's good now.
  • · Replies 67 ·
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 46 ·
  • · Replies 58 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 95 ·
9K
