Three masses two strings system: lagrange and eigenvalues
kejal
We have a three mass two strings system with:
m_1 string M string m_2
The end masses are not attached to anything but the springs, the system is at rest, and k is equal for both strings and m_1 and m_2 are equal. The distance between to m_1 and m_2, on both sides of M, is b.
It appears to be the same problem as in this thread:
https://www.physicsforums.com/showthread.php?t=397347
But we want to find the Lagrange equation, use the Euler-Lagrange equation to find the equations for movement and then finally the eigenvalues.
L=T-V
\frac{\partial L}{\partial x} = \frac{d}{dt}\frac{\partial L}{\partial \dot{x}}
T=\frac{m\dot{x}^{2}_{1}}{2}+\frac{M\dot{x}^{2}_{2}}{2}+\frac{m\dot{x}^{2}_{3}}{2}
V=\frac{k}{2}((x_2 -x_1)-b)^2 + \frac{k}{2}((x_3-x_2)-b)^2
L=T-V=\frac{m\dot{x}^{2}_{1}}{2}+\frac{M\dot{x}^{2}_{2}}{2}+\frac{m\dot{x}^{2}_{3}}{2}+\frac{k}{2}(b- (x_2 -x_1))^2 + \frac{k}{2}(b - (x_3-x_2))^2
Using the Euler-Lagrange we then got:
m_1 \ddot x_1 +k ((x_2 - x_1)-b)=0
m_2 \ddot x_2 + k (x_3 - x_1)=0
m_3 \ddot x_3 +k (b - (x_3 - x_2))=0
And then we're pretty much stuck with what to do to find the eigenvalues, especially with b, but an idea was:
Using \omega^{2}=\frac{k}{m}:
\ddot x_1 = -\omega^{2}x_2+\omega^{2}x_1+\omega^{2}b
\ddot x_2 = -\omega^{2}x_3 +\omega^{2}x_1
\ddot x_3 = -\omega^{2}b + \omega^{2}x_3 -\omega^{2}x_2
Then we assumed x=Ae^{iwt}, so \ddot x=-\omega^{2}Ae^{iwt}=-\omega^{2}x
Then λ=-\omega^{2}
A\bar{x}=λ\bar{x}
Calculating \left|A+ \omega^{2}I\right|=0 gave us 10 \omega^{6}b+3 \omega^{4}=0 which is... how about no.
Any hint on what to do with b? Can we just exclude it or how should we think? All and any help/hints would be highly appreciated!
Hello, kejal. Welcome to PF!
Note that in a normal mode, each mass oscillates about its equilibrium position. Things will be easier if you let ##x_1## denote the displacement of ##m_1## from its equilibrium position. Similarly for the other masses. You will then find that ##b## will not appear in the Lagrangian.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
