Three Pan Balance, 15 Coins.
  • Thread starter wubie
  • Tags
    Balance
In summary, the conversation discusses a question about determining a counterfeit coin using a three pan balance and limited weighings. The solution presented involves dividing the coins into groups and recording the results of each weighing to identify the counterfeit coin. The effectiveness of the solution is debated, but it is agreed that it can be done in two weighings without prior knowledge of the weight of the counterfeit coin.
wubie
Hello,
I have encountered a question in my discrete mathematics class and I was wondering if I have solved it correctly. I can't remember the question to the word but I will try my best to state it correctly
You have 15 coins. One is counterfeit. You also have a three pan balance (like a three leaf clover without the stem and balanced where the three leaves meet). If one of the three pans is heavier, then the balance will tip to the heavier pan.
Given that you must pay $100 per weighing , how much must you pay to determine the counterfiet coin? That is, determine the counterfiet coin in as few weighings as possible.
If you can, find a nonadaptive solution.
An adaptive solution is a solution in which the action at each step is adapted to the outcome from the previous action.
A nonadaptive solution is a solution in which all the actions are fully predetermined.
Now I think I have come up with a NONADAPTIVE solution. And I believe that the counterfeit coin can be identified in two weighings.
First, label each coin 1 to 15. Then construct a table with a row from 1 to 15 (the number of each coin):
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Under each numbered coin put a one if it is in the heavier pan. If not, put a zero.
First weighing:
Divide the fifteen coins into four groups; three groups of four, and one group of three.
Group one: 1,2,3,4
Group two: 5,6,7,8
Group three: 9,10,11,12
Group four: 13,14,15.
Weigh groups one to three against each other. Leave group four alone.
Record a one underneath the coins which are part of the heavy pan.
Second weighing:
Group one: 1,5,9,13
Group two: 2,6,10,14
Group three: 3,7,11,15
Group four: 4,8,12.
Once again weigh groups one to three against each other and leave group four alone.
Record a one underneath the coins which are part of the heavy pan for the second weighing.
Now look at the table. The coin with two ones underneath should be the counterfeit coin.
EXAMPLE: Let's say that 11 is the heavy coin. But we don't know it yet. Now execute the above algorithm.
0 0 0 0 0 0 0 0 0 1 1 1 1 1 1
1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 | Numbered Coins
0 0 0 0 0 0 0 0 1 1 1 1 0 0 0 | First weighing
0 0 1 0 0 0 1 0 0 0 1 0 0 0 0 | Second weighing
As you can see, there are two ones underneath the coin numbered 11. Which is exactly what we want.
Does this seem like a solid, nonadaptive solution?
Any thoughts on the subject are appreciated. Thankyou.
Mathematics news on Phys.org
I suppose you also know the counterfeit coin is heavier than the real thing?
Anyways, your solution looks good to me. As a plus, you can even tell if all 15 coins happen to be good!
Yes. The counterfiet is supposed to be heavier.
Thanks for looking this over Hurkyl. This was a question on my midterm today. I thought I did it correctly, but I wasn't sure; I didn't have time to check.
Cheers.
The problem is nearly trivial if you know that the counterfeit coin is heavier (or lighter). It can be done in 3 adaptive trials for 12 coins, without that knowledge. 15 may take 4, you may not know without an extra measurement whether the counterfeit coin is light or heavy.
Your algorithm is not clear to me, looks like you are making at least 4 measurements, with knowledge of the weight it is easy to do in 3 Your algorithm does not seem to guarantee the bad coin in as few measurements as possible. What is the number of measurements required to isolate the coin?
2 weighings, non adaptive. You don't need to know ahead of time whether it is light or heavy.
seperate coins into 3 groups of 5.
put 4 of 5 on each pan. record.
for each group
- move one coin clockwise
- one counter clockwise
- one off of the pan
- put the unweighed coin on the groups original pan.
record
Njorl
Edited to add - I believe my solution is really the same as yours. You don't need to know if the fake is heavy or light ahead of time. At some point, one balance will be in a different position than the others. If it is up, the fake is light. If it's down, the fake is heavy.
In my initial post I missed the 3 pan balance. I assumed a 2 pan balance, now your algorithm make more sense!
Yes. It is a three pan balance. That makes the question a little less trivial.
As far as whether the coin is lighter or heavier, it believe it doesn't make a difference. It one pan is lighter than the other three, I would think that the two pans that are heavier and the same weight would cause the lighter pan to rise.
In any case I would also think the above solution would work - just put one underneath the pan with the light coin.
I haven't thought about it too much, but I don't see a problem with that.
Cheers.
Related to Three Pan Balance, 15 Coins.
1. How does the Three Pan Balance work?
The Three Pan Balance is a simple tool used to compare the weights of different objects. It consists of three pans suspended from a horizontal beam, with a pointer attached to the beam to indicate the balance. The goal is to place objects of unknown weight on one pan and known weights on the other two pans to achieve balance.
2. What are the 15 coins used for in the Three Pan Balance?
The 15 coins in the Three Pan Balance are used as known weights to compare the weight of an unknown object. Each coin has a specific weight, ranging from 1 gram to 15 grams, allowing for a wide range of weights to be measured.
3. How do you use the Three Pan Balance to find the weight of an object?
To find the weight of an object using the Three Pan Balance, you first place the object on one pan and then add coins to the other two pans until the balance is achieved. The number and weight of coins needed to achieve balance can then be used to calculate the weight of the object.
4. Can the Three Pan Balance measure weights other than grams?
Yes, the Three Pan Balance can measure weights in units other than grams, as long as the known weights used on the other two pans are in the same unit. For example, if the known weights are in kilograms, the balance can measure weights in kilograms.
5. What are some common uses for the Three Pan Balance?
The Three Pan Balance is commonly used in science experiments and classrooms to teach about weight and measurement. It is also used in industries such as agriculture, jewelry making, and pharmaceuticals for precise weight measurements. Additionally, the Three Pan Balance is used in forensic investigations to measure the weight of evidence.
  • Math Proof Training and Practice
  • Set Theory, Logic, Probability, Statistics
  • Quantum Physics
9K
  • Precalculus Mathematics Homework Help
  • General Discussion
