Exploring the Equivalence of Time and Motion: A Scientific Perspective
In summary, while there may be complications with including light in a theory of a motionless universe, the idea is interesting and should be pursued further.
madness
815
70
My question here borders on philosophy, but I'm posting it here because I'd like to discuss it in a scientific context.
I was thinking about time and motion the other day, and how I cannot distinguish between a motionless universe and one without time. For example, if everything were to stop for a million years, and then start moving again exactly as it was, this would be indistinguishable from no time having elapsed at all.
In Einstein's equivalence principle, he notes that the effects of gravity are locally indistinguishable from the effects of inertial motion. From this he promotes the "coincidental" equivalence to a "law of nature".
So I was wondering if it would be possible to make a similar step with the equivalence of time and motion. For example, we might decide that if we transform to a frame where everything is motionless, then no time elapses in this frame. I know what I'm saying is a bit rough around the edges but I'm interested in how to take what seems like a philosophical concept and turn it into a testable theory.
I believe that a motionless muon will still decay, similarly with other unstable particles. So I think that it is incorrect to say that a motionless universe is indistinguishable from one without time.
Jesse, does the muon decay not create motion and change? So even this would cease if there was no time.
The commonest definition of time is that 'time is change'. We can only percieve time by being aware of change. No change -> no time. No time -> no physics. Which makes the question philosophical not about physics.
This question arises in the context of classical mechanics. Say you consider conservation of energy to be more more fundamental than Newton's laws. Let U be the potential energy and K the kinetic energy. Given conservation of energy, we have for an object released in a uniform gravitational field
[tex]
a=\frac{dv}{dt} = \frac{dv}{dK} \frac{dK}{dU} \frac{dU}{dy} \frac{dy}{dt} = \frac{1}{mv}(-1)(mg)v
[/tex]
There are two possibilities here: (1) v=0, and (2) [itex]v \ne 0[/itex] and a=-g. If v=0 you can't cancel the v's; this is simply the mathematical way of saying that the object can hover indefinitely while conserving energy.
In the context of general relativity, this has a very natural interpretation. GR has general covariance, so you can elastically stretch and contract the time coordinate, and the laws of physics are still obeyed.
While this is a good point, decay implies motion by its very nature. An utterly motionless universe would have to be one without change; without decay or growth.
RasRemi said:
While this is a good point, decay implies motion by its very nature. An uterly motionless universe would have to be one without change; without decay or growth.
Particle decay is different from our ordinary notions of decay, it just means one type of particle vanishes and some other particle or particles appear in its place. But for most type of particle decay I think the decay products include photons, which can't help but move at the speed of light even if the original particle was motionless in whatever frame we're using.
There are definitely complications. I might want to start off with a simplified GR type scenario where there are only classical particles moving under mutual gravity. Then there are certain gauges (e.g. transverse traceless) in which particles stay still and the coordinates move in order to compensate. I don't know if it would be possible to include light. I think it would be interesting to investigate the consequences of imposing an equivalence between time and motion, but I don't think I have enough genius to actually make such a theory.
If you have multiple particles at exactly the same distance for some time you imply:
1. The temperature of the 'gas' of such partciles = exactly 0, which is impossible because Unvirse started from the hot state and every act of cooling down decrase tempreature by some ratio, so you can't reach 0 in finite time;
2. In QM p=0 implies coordinate is *absolutely* unknown, or, if you define 'motionless' using the coordinate, then it also a nonsense because of HUP. In any case, the cosmological horizon sets the limit on how low the p and temperature can be.
No, it doesn't. A decay is a change, certainly, but not all change is motion. The OP was specific about motion, not other changes. I think it is incorrect.
To measure time we need a clock. An ideal clock can be looked at as a closed system with no external forces acting on it, which, from a given configuration, chages and returns to exactly the same configuration, and so will repeat this cycle continuously. One such cycle is its period or tick. This definition implies changes of state of the system within the cycle and I suppose these changes imply motion of some sort, maybe just at atomic level. So without some motion in the universe we cannot have a clock and so cannot measure time. In this case, is the concept of time meaningless, or is time just not measureable. If nothing ever happens then we would have no use of a clock or time anyway. Does that make any sense.
Matheinste.
Matheinste.
Yes. That's what I was saying. The only arguable thing is - can there be change without motion ?
Matheinste.
If I have a universe consisting entirely of emtpy space and a clock, I can make a change of coordinates such that the hands of the clock stay still in the new frame. Do you argue that time is meaningless in this new frame?
Is such a change of coordinate system possible?
Matheinste.
Actually I'm not sure, but when studying gravitational waves the transverse traceless gauge is used, which is a coordinate system physically represented by taking test masses to mark the coordinates. Then free masses stay stationary in this frame even in the presence of a gravitational wave.
Too complicated for me.
Matheinste.
Motionless universe?! What kind of universe is that? Do Newtons laws follow there? If Yes then Planets can't suspend near the sun without revolving?? Or gravitational forces vanishes in Motionless universe? If Motionless universe is to be considered as an snapshot of our universe, then there is no time in it. Its like saying,
Hey, look, 1000 years of motionless universe just passed just now and resumed and we didn't notice it!
If the universe everywhere were to stand still for a million years simultaneously for what appears to be one Planck time interval according to one set of observers in a common rest frame it might seem that this frozen state would be undetectable because no physical process could detect this passing of a million years locally. However, to a single observer, far away frozen events would happen later than nearby frozen events and he would notice the universe getting out of sync due to light travel times. If the frozen state events were synchronised in such a way that the information about the frozen events all arrived simultaneously at a single observer to hide the event, then any other observer spatially separated from the first observer or moving rleative to the first observer would notice the pause, due to diefferences in simulteity.
How would you be aware of either?
Am I the only person who thought, "why on Earth is this guy asking about time & motion studies? What does workplace efficiency have to do with physics." Then I remembered why I shouldn't read the forums when I'm tired. :smile:
Anytime someone asks what would happen if time stopped, or accelerated... I just ask, "what is time?". If you follow that conversation to its conclusion, they usually answer their own questions by realizing the lack of a universal time, and maybe even a non-thermodynamic/psychological arrow of time.
Edit: At the risk of angering the Olympian lords of PF by talking about getting QM in your SR/GR... a truly MOTIONLESS universe, devoid of even the minor fluctuations dictated by Uncertainty is impossible (in this universe, during its known history). In a time-stopped universe, or one in which all motion ceased, particles would ALL have definite positions, velocities, etc.
I suppose you could say that a god would be a being able to view and interact with the universe in just such a fashion. That is fanciful of course, but then this is philosphical to begin with.
I wouldn't be aware, which is hard to reconcile with my subjective experience of time flowing. If time were to speed up, stop, go backwards or even jump from time to time I wouldn't notice.
I was interested in taking an idea like the equivalence of time and motion, and seeing how it might be incorporated into a physical theory.
Well... CPT symmetry isn't perfect, and it remains to be seen if a time-reversed BH would emit anything other than more Hawking Radiation.
I think the notion of an arrow of time is purely thermodynamic and subjective for life. Then again, that leads to anthropic thinking. *shrug*... weird stuff.
The thermodynamic arrow of time is an asymmetry, which does not in any way explain our subjective experience of flow. Time could be asymmetric and yet completely static. Time could have the same asymmetry yet we could experience it as going backwards. The only explanation I can think of for our experience of flow is that it's an evolutionary advantage.
As I said, don't assume CPT symmetries.
That evolutionary advantage you refer to is what Stephen Hawking called the 'psychological' arrow of time. Just as you're implying, he believed that life in this universe needed to follow the thermodynamic arrow of time to BE life. We're machines that consume organized forms of energy and emit thermal radiation. There is no way we could be life of any imaginable form in a time-reverse scenario if the basic notion that we eat food to live, adding to the overall entropy of the system in which we live, can't be separated from being alive.
Then again, that is anthropic thinking again, and no real justification. The best that we can say as human beings is that the thermodynamic arrow of time represents the overall flow of time as best we can tell. If there is another valid way of experiencing time, it's not something we could survive.
If we are to assume that the experience of flow somehow generates an evolutionary advantage, we are assuming that our conscious experience actually has some physical effect on things, rather than being an inert by-product. I'm don't that is accounted for in standard science, other than quantum interpretations involving consciousness like the one given by Wigner.
You're completely missing what I'm saying, which has nothing to do with consciousness or life having an effect.
http://www.math.cornell.edu/~numb3rs/luthy3/thearrowoftime.html For a synopsis...
or from the classic book...
http://books.google.com/books?id=aK...0CAYQ6AEwAA#v=onepage&q=arrow of time&f=false
See page #259 (excerpt from 1985 submission by Stephen Hawking) at top.
Ok then you've misunderstood what I said earlier. Neither the entropic or psychological arrow of time as Hawking defines them explain the experience of flow. We could still remember the past and not the future yet not experience any flow or experience the flow in the opposite direction.
What do you base that rather bold statement on? i.e. Please Cite.
EDIT: Remember that we couldn't ENCODE memories using our current physiology if the thermodynamic arrow of time were reversed. The entire proposition is that the two are inextricably linked for obvious reasons.
You might be right about the physiology part. Hawking points out two asymmetries in time, one psychological and one physical. In the same way that a thermodynamic arrow of time doesn't imply a physical flow of time (the block universe can still hold), a psychological arrow of time doesn't imply a perceived flow of time. I don't think it's a bold statement. I'm just saying that the asymmetry is conceptually distinct from the apparent flow. This is not to say they are unrelated, but that we haven't explained the relation between them.
Are you referring to the mass of an object never varying between it's gravitational pull and it's inertial motion?
Fgrav=Gmgravm/r2
P=minertialv
in which mgrav and minertial for an object are equal?
And you wish to find a way in which the motion of a frame is equivalent to its time?
Ok, in this case we are in perfect accord.
Related to Exploring the Equivalence of Time and Motion: A Scientific Perspective
What is the concept of time and motion equivalence?
The concept of time and motion equivalence is the idea that time and motion are fundamentally linked and can be measured and compared in a similar way. This concept is based on Einstein's theory of relativity, which states that time and space are relative to an observer's frame of reference and can be affected by the speed and acceleration of an object.
How is time measured in relation to motion?
Time is measured in relation to motion using a unit called a second. This unit is defined as the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the cesium 133 atom. This is a consistent and precise way to measure time, regardless of an observer's frame of reference.
What is the significance of the equivalence of time and motion?
The equivalence of time and motion has significant implications in the field of physics and our understanding of the universe. It helps us better understand the relationship between space, time, and motion and has led to groundbreaking theories such as relativity and quantum mechanics. It also has practical applications in fields such as GPS technology.
How does the concept of time and motion equivalence relate to the speed of light?
The concept of time and motion equivalence is closely related to the speed of light. According to Einstein's theory of relativity, the speed of light is the maximum speed at which all matter and information can travel. This means that as an object approaches the speed of light, time and motion become more and more equivalent, and the laws of physics change.
Can the equivalence of time and motion be observed in everyday life?
Yes, the equivalence of time and motion can be observed in everyday life. For example, GPS technology relies on the concept of time dilation, which is a result of the equivalence of time and motion. Additionally, the effects of time dilation can be observed in high-speed travel, such as airplanes and spacecraft, where time appears to pass slower for objects moving at high speeds compared to those at rest.
