Time difference of events when moving at relativistic speeds
The discussion focuses on calculating the time difference between two events occurring on different planets when observed from a spaceship traveling at 0.8c. The Lorentz transformation is applied to determine the time coordinates of the events in the moving frame. Event A occurs at tA'=0 on Planet A, while Event B occurs at tB'=2 minutes on Planet B, which is 8.3 light minutes away. The calculations reveal that Event B is perceived to occur 464 seconds before Event A from the observer's perspective. The use of time dilation and the Lorentz equations is emphasized for accurate results.
Whistlekins
Lets say that Planet A and Planet B are moving in the the same inertial reference frame. The distance between them is 8.3 light minutes. Event A occurs on Planet A at t=0, and Event B occurs on Planet B at t=2 minutes. If an observer is traveling from Planet A to B at 0.8c, what is the time difference between the two events?
I want to say that we just need to use the Lorentz transformation, plugging in 2 minutes as the proper time, but it's probably not that simple.
probably not.
event A occurs at tA'=0, xA'=0 in planet frame (taking A as the origin).
event B occurs at tB'=2 min, xB'=8.3 light minutes in planet frame.
find out when these are in the moving frame tA, tB.
you get the piece due to time dilation, but also a piece due to the fact
that planet B is not sitting at the origin.
So if I use Lorentz transformations and say tA = γ(t'A - v/c2 xA), similarly for tB, I get tA = 0 obviously, and tB = -464s, meaning that Event B occurs 464s before Event A in the reference frame of the observer? I hope I'm understanding this properly.
More help to Clarify
This should just be a straightforward application of time dilation.
Assume your ship's origin lines up with A's origin. x=0, t=0, x'=0, t'=0.
Now B is at rest with respect to A, so they are in the same frame, call this the ground frame.
Your event is going to take place in the ground's frame at (x=8.3 light-mins, t = 2 min).
Thus, use x'=γ(x-vt) where you plug in the ground's frame x and t from above. The x' that pops out is the coordinate where the ship observes the event to take place.
Use the next Lorentz equation: t'=γ(t-vx/c^2) where you plug in the ground frame's x,t from above. This will give the t' that the ship observes. If you get an overall minus on the t', that's okay, that just means it happened before the orgiins lined up in the ship's frame.
