To find the forces acting in a system in equilibrium
The discussion revolves around a problem involving forces in a system in equilibrium, specifically analyzing the forces acting on a ring and connected bars. Participants are exploring the relationships between these forces and moments, as well as the implications of their calculations.
  • The original poster attempts to resolve forces and moments in a system involving a ring and bars, questioning where their reasoning diverges from the book's answers. Some participants suggest considering additional forces, such as the torque from the weight of a bar, and others reflect on the visualization of the system.
Participants are actively engaging with the problem, with some providing insights that lead to a better understanding of the forces involved. There is acknowledgment of the need to consider additional factors, such as the weight of the bar, in the calculations. The discussion is ongoing, with various interpretations being explored.
There is mention of confusion regarding the visualization of forces and moments, particularly in how to account for the weight of the bar when analyzing the ring alone. The discussion also touches on the implications of angles on the forces involved in the system.
gnits
moments
Could I please ask where I have gone wrong with my reasoning in the following question:
The answers in given in the book are:
(1/2)W tan(Ө)
W
vertically
(1/2)W tan(Ө) horizontally
Here is my diagram:
Considering the system as a whole:
(In the text below "Ya" and "Xa" are the forces at the hinge at A)
Resolving vertically gives:
Ya + R = 2W + ω (call this "equation 1")
Resolving horizontally gives:
F = Xa (this agrees with the book answer)
Taking moments about C gives:
W * a sin(Ө) + W * 3a * sin(Ө) = Ya * 4a * sin(Ө)
which gives:
Ya = W (this agrees with the book answer)
And so from "equation 1" we have that R = W + ω (call this "equation 2")
Now, considering the ring alone and taking moments about B gives:
R * 2a * sin(Ө) = ω * 2a * sin(Ө) + F * 2a * cos(Ө)
which gives:
R * tan(Ө) = ω * tan(Ө) + F
So using "equation 2" gives:
F = W * tan(Ө)
But book answer is F = (1/2) * W * tan(Ө)
Where have I reasoned wrongly?
Thanks for any help.
You have forgotten the moment (torque) produced by BC's weight.
Thanks very much for that. Indeed, if I include the torque produced by BC's weight everything works out.
This torque is given by W * a sin(Ө)I guess I am having trouble justifying to myself, why, when I am considering forces on the ring only, I need to include W due to the weight of BC in this way. If I imagine a diagram with the ring only then, if anything, I would label the force on the ring due to BC as being an arrow pointing vertically downwards from the ring of magnitude W. But then it's moment about B would be be
W * 2a * sin(Ө)
not W * a * sin(Ө) as I use above to get the right answer?
How am I thinking of this wrongly?
*EDIT* I think that my confusion is one of visualization. I think that, "mentally", I should be thinking in terms of considering "the rod BC and the ring" as the entity which I am considering in isolation, rather than just "the ring", then indeed I would use W * a sin(Ө)
You have a mechanism that would tend to relocate itself to the point of lowest potential energy, where bars AB and BC would become both vertical if nothing would be holding ring C in its position.
AB would simply rotate, while BC must rotate and move, while following the circular trajectory of point B on one end and a horizontal trajectory on the other end.
Thanks all for the replies. They have helped me to solve to problem.
As the angle between the bars increases, the magnitude of the horizontal reaction at pivot A and the necessary friction force at ring C dramatically increases.
At 180 degrees, the value of those forces will be infinite.
Please, see this practical application of this principle of increasing mechanical advantage:
https://roperescuetraining.com/physics_angles.php
You are welcome. :)
