Maximizing Torque: Comparing Square and Rectangular Coils in Magnetic Fields
  • Thread starter Thread starter NotaPhysicsMan
    Coils Torque
The discussion centers on calculating the ratio of maximum torque between a square coil and a rectangular coil, both made from the same length of wire and containing a single turn. The square coil has equal side lengths, while the rectangular coil has sides in a 1:2 ratio. Initial calculations suggested a torque ratio of 1:2, but it was later corrected to account for wire length, leading to a revised ratio of 1.125. The importance of using the correct dimensions and understanding the wire length used for each coil was emphasized. The final conclusion highlights the need for careful consideration of coil dimensions in torque calculations.
NotaPhysicsMan
Hey,
Any help will do:
A square coil and a raectangular coil are each made from the same length of wire. Each contains a single turn. The long sides of the rectangle are twice as long as the short sides. Find the ratio t(tau) square/t rectangle of the maximum torques that these coils experience in the same magnetic field when they contain the same current.
Ok what I know:
t=Fl, maximum torque is when the normal is at 90 degrees to the field.
I know that the lengths for all sides of the square are equal, so x.
And the rectangle has two sides x, and two sides 2x. Since we want max torque, we want the bigger lever arm so I'll use 2x.
----o---- 2x rectangle
--o-- x square
Ok so t=Fl
=IABsin@/IABsin@
=I(x^2)Bsin@/I(2x(x)Bsin@)
Since the I, B and sin@ are constant
ts/tr= x^2/2x^2
ts/tr=1/2? :confused:
Anyone want to verify thanks!
Anyone? Please :)
Aren't these two statements contradictory?
Your rectangle is using 1.5 times as much wire as the square.
OH crap, I see. Ugh well let's see then 1.5 x for each side of the square.
Therefore ts/tr= (1.5^2)/(2)=1.125
Thanks for the reminder!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
