Verifying Torque and Motion Problem Solution
  • Thread starter Thread starter Hockeystar
    Motion Torque
The discussion revolves around verifying the solution to a torque and motion problem involving a pulley system. Key points include the need to account for the pulley's mass and friction, which affects the tension in the strings and the resulting acceleration. Participants emphasize that the tensions cannot be equal due to the pulley's mass, which would prevent rotation if they were. The correct acceleration was recalculated as 7/3 m/s², and the torque on the pulley was determined to be 0.7 Nm. Overall, the conversation highlights the importance of considering all forces and torques in such mechanical problems.
Hockeystar
All info is in attachment
I'm asking if someone can verify whether or not my work is correct. I'm doubting whether I solved the problem correctly or not.
looks alright
I wonder table is smooth or not.
You got the wrong acceleration. Even if friction is neglected, the pulley has to be taken into account, as it's not massless. Here is my solution (assume that the table is frictionless):
_ For the 2-kg block:
m_2g - T_2 = m_2a
T_2 = 20 - 2a
_ For the 4-kg block:
T_4 = m_4a
T_4 = 4a
_ For the pulley:
T_2r - T_4r - M_f = I.\alpha = \frac{1}{2}m_pr^2\alpha = \frac{1}{2}m_pra
T_2 - T_4 - 2.5 = 1.5a
Thus:
20 - 2a - 4a - 2.5 = 1.5a
a = \frac{7}{3} m/s^2
_ The torque on the pulley:
M_p = I.\alpha = \frac{1}{2}m_pr^2\alpha = \frac{1}{2}m_pra
M_p = 0.7 Nm
Oh they ask for the torque on the pulley, which means this torque includes the friction's torque.
m_2g - T_2 = m_2a
T_2 = 20 - 2a
T_4 = m_4a
T_4 = 4a
_ For the pulley:
Thus:
M_p = 0.7 Nm
You mean tension on the string are not the same for 2 bodies. We consider same tension. According to hockeystar, you should take g= 9.8 ms-2.
It is impossible for the tensions to equal. Since the pulley is not massless, if the tensions equal, their torques on the pulley cancel each other, plus the frictional torque which prevents the pulley to rotate, the pulley will no way rotate.
If the pulley is massless, its moment of inertia is zero. From the equation: torque = (moment of inertia) x (angular acceleration), we shall see that torque = 0.
Sorry for not noticing g=9.8 m/s^2 :) So all to do is just recalculating.
Thanks . I got a lot of knowledge.
