Answer: Torque of Swallow on 40 N Rod with 1 m Length
  • Thread starter Thread starter Nirupt
    Torque
To determine the force exerted by the string to keep the 40 N rod horizontal when a 2 kg swallow lands on it, the torque created by the swallow must be balanced by the torque from the string. The swallow applies a downward force of 19.6 N at a distance of 0.3 m from the hinge, generating a counterclockwise torque. The string's force, acting at a distance of 1 m from the hinge, must counter this torque to maintain equilibrium. Proper visualization of the forces and their moments is crucial for solving the problem accurately. The correct setup will lead to the calculation of the string's force needed to keep the rod horizontal.
Nirupt
James Gomer holding a uniform 40 N rod of length 1 m horizontally with a hinge on its left end and a vertical string on the right end. Now suppose a fully laden swallow with a mass of 2.00 kg lands and squawks loudly on the rod at a point 30.0 cm to the right of the hinge. Now what is the force exerted by the string to keep the rod horizontal?
I figured out that the string with no force exerted on the rod is 20N, so Far I have
Ʃfnet = 2kg*9.8*20(moment arm) - F*20
I don't think I have my setup correct though.. I'm just not visualizing this well
What point are you taking moments about? List the forces and their orthogonal distances from that point.
