How Do You Calculate Torque Around Point D in a Lever Setup?
To calculate torque around point D in a lever setup, the force at point A generates torque at the fulcrum using the formula F*(alpha/2)*sin(theta). The force in member BC acts as a reaction force from the applied force at A. This reaction force is crucial for determining the torque at point D, as it influences the force at the top of member CD. The setup specifies that member AB is fixed at the fulcrum, allowing for a straightforward analysis of the forces involved. Understanding these relationships is essential for accurately calculating torque in this scenario.
BatsDude
Hi guys,
It's been a while since I've done much resolving forces stuff, and I'm struggling to make sure what I'm doing is right. I have a setup like below, and I want to find the torque around point D due to the force acting at point A.
I've had a couple attempts but I feel like I'm just guessing and I'm not sure if I'm correct.
I know the force acting at A produces a torque at the fulcrum of F*(alpha/2)*sin(theta) but is this the force that's also seen in the BC member? From what I understand, if I can find the force acting in the BC member, it should be easy to find the torque around point D.
Any help would be good! Thanks
This is a question about the problem: is AB fixed on the fulcrum (just pivot), or can it also slide up and down in relation to the fulcrum? It has been a little while for me, as well.
Hi,
It's fixed on the pivot. Apologies for the lack of detail!
For anyone playing along, I've got a solution.
The force in BC is the reaction force from F in a simple lever setup.
Then this is the force acting at the top of member CD which creates the torque.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
