Solving Torque Question 3.12: Find Force F
  • Thread starter Thread starter SS2006
    Torque
The discussion focuses on solving torque problems related to static forces and moments. The original poster struggles with calculating the force F in a torque equation, realizing they need to re-evaluate the distances used in their calculations. They also express confusion regarding tension in a tie rope and the forces at hinges in subsequent problems, seeking clarification on how to approach these statics problems. A response emphasizes the importance of identifying all acting forces and torques, breaking them into components, and applying Newton's second law to establish equilibrium equations. The conversation highlights the need for a solid understanding of static equilibrium to solve these types of physics problems effectively.
SS2006
http://img210.imageshack.us/img210/3923/q17tp.jpg
Question 3.12 (ignore the 0.80 i have written under it)
i don't know what to do, well first i started the torque fbd at the first tire
torque 1) - 700 * 0.25L (negative cause its clockwise)
torque 2) - 8000 *0.5L
torque3) - 900 *0.75L
torque4) F * 1L
-175 - 4000 - 675 + F
4850 = F
as you see that's not the right answer
i know i did something wrong let me know
Looks like you need to re-examine the distances that you're using in your torques. Re-read the problem and take a closer look at the figure. Also remember that you'll need to divide your final answer by 2 since there are two wheels at the front and back :)
i knew i had the distances werong
im blanked for some reason :(
from that same question sheet btw
3.16
i got 2.9kN as teh tension in the tie rope, but whaen they ask for force of the hinge on the beam, believe it or not i dotn remember being taught this, what do you do in this case.
as for 3.15
they ask for the force components at thehinges
once again i did get 670N, but in the answers there's H=670N V= 1.6kN
i really don't know this, a quick lesson would be apprecaited thans
There's a basic strategy for attacking these kinds of problems. They're generally called statics, by the way, since the situations are supposed to be static (i.e. nothing's moving).
Basically what you want to do is to determine exactly what forces and torques are acting on the object in question. That would be the floor of the car in your first question and the beams in your second two.
Once you've determined the forces that are acting on the object break them up into components and use Newton's second law (F=ma) to get a system of equations relating the various forces to one another. In these cases nothing's moving so your acceleration will always be zero, i.e. you'll be setting the sums of your forces and torques equal to zero.
For instance, in the case of the situation in Figure 3-15 I'll go through the forces that are acting on the beam in the vertical direction. You have a gravitational force from the weight of the beam itself that's pulling down, you have the weight of the mass hanging off the end which is also pulling down, you have the vertical component of the force exerted by the rope which is pulling up, and you have a vertical component of force from the hinge which is pushing down. The sum of all these forces must equal zero.
Simmilarly you should be able to come up with equations relating the horizontal components of force which are acting on the beam, and all of the torques as well. Once you've done this you will have a system of three equations with three unknowns that you should be able to solve using standard algebraic techniques.
tha tmade a lot fsense thanks so much
i understood vetical part very weel
but what torques are in the horizontal part?
