Torque required to rotate a hollow cylinder containing chips
The discussion focuses on calculating the torque required to rotate a hollow netted cylinder containing 5 kg of metal chips for a prototype designed to remove cutting oil during Gun Drilling. Key considerations include the impact of pressurized air, which should be directed from underneath at an angle opposite to the rotation to reduce rolling resistance and enhance drying. Supporting the central rod at its free end is suggested to minimize torque requirements and motor wear. The arrangement's design is crucial for optimizing airflow and chip movement. Overall, effective airflow and structural support are essential for improving the efficiency of the oil removal process.
Sandeep Swarup
I am designing a prototype to remove cutting oil from waste metal chip during Gun Drilling.
My prototype consists of a netted(meshed) metal cylinder rotating horizontally about its axis with help of shaft and a pressurised air blown from above. The metal chips will be put inside netted cylinder which will rotate with help of shaft through motor and oil wil drip down.
The only data I have is amount of metal chip that I will insert in hollow netted cylinder I.e 5kgs
How shall I proceed with calculation to find out required torque, shaft diameter,RPM
Can you provide a rough drawing of the arrangement?
PDF uploaded is the DESIGN of the prototype
What does the pressurized air do again?
Quite a good blast would be needed to blow the oil off the chips if that is the intent.
Don’t know how much torque you’ll need, but I can tell you that the requirement will be significantly reduced by supporting the central rod at its free end. This would also reduce wear on the motor.
Also, since a lot of the resistance to rotation will come from the oily metal chips sticking together and trying to ride up the side of the mesh, having your air flow come up from underneath, at an angle opposite to the direction of rotation, will also help reduce rolling resistance, while drying the chips more quickly. It would tend to break up the clumps and expose more surface area.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
