Is Total Pressure Constant at the Same Altitude for Any Moving Flow?
  • Thread starter Thread starter su214
    Confused Pressure
Total pressure is the sum of static pressure and dynamic pressure, with static pressure remaining unchanged under local atmospheric conditions. It is correct that static pressure equals total pressure when the fluid is static, and total pressure is always greater than or equal to static pressure. As fluid velocity increases, static pressure decreases, but it will not reach zero; instead, it approaches Mach 1, where shockwaves form and static pressure actually increases. The concept of total pressure being constant at the same altitude applies to moving flows, but dynamic pressure varies with the frame of reference. Understanding these principles clarifies the relationship between static and total pressure in fluid dynamics.
su214
total pressure , I'm confused !
hello :)
i'm new here ...
i'm confused in poits regards pressure
now please correct me if I'm wrong...
1-static pressure is equal to the total pressure if the gas is static (V=0)
2- total pressure is always equal or bigger than the static pressure
3-as the velocity increases the static pressure decrease
if these statements are correct then
1- is the ambient pressure is equal to total pressure and the total pressure is constant at same altitude for any given moving flow
-ex:at sea level-?
2-if the above statement is correct ,then in case of increasing of fluid velocity will its static pressure will equal zero at certain velocity ?
3-
here :
http://img801.imageshack.us/img801/7098/29329605.jpg"
the underlined lines confused me very much the author say that " the static P and T remain UNCHANGED "??
and the stagnation reference depend on the frame of reference?
i can't understand the underline lines...
Total pressure is the sum of static pressure and dynamic pressure, where dynamic pressure is proportional to V^2. Since velocity is dependent on the reference frame so is dynamic pressure and therefore total pressure. The static pressure remains unchanged because it is dependent on the local atmospheric conditions which do not depend on your frame of reference. So if two people are standing next to each they both feel the same static pressure but if one person starts to run forward they feel an additional pressure on their front side. The pressure they feel is the total pressure which is the local static pressure plus the dynamic pressure based on their velocity. The person standing still only feels local static pressure which in their case is the total pressure because they are not moving relative to the air.
To answer this question:
"in case of increasing of fluid velocity will its static pressure will equal zero at certain velocity ?"
No, because as the fluid velocity increases it will approach Mach 1 where shockwaves will form and static pressure increases across a shock.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
