Where Can I Find a Simple Guide to Transformer Design?
A request for a simple guide to transformer design highlights the difficulty in finding accessible resources beyond standard equations. Users express confusion over the relationship between turns and voltages, seeking clarification on basic design principles. Recommendations include a PDF from a Colorado university and a website focused on basic design concepts. The discussion emphasizes that transformer design involves balancing various factors, such as turns, impedance, and material properties. Overall, the community suggests that finding a knowledgeable designer may be beneficial for those struggling with the complexities of transformer design.
mfc5200
Does anyone know of a good link to basic transformer design? I keep seeing the standard equations but they don't seem like much help. I can't seem to find any good guides for designing the most basic transformer
For example, I will see equations relating the ratio of turns to the ratio of voltages, but does that mean I can go from 1 turn to 2 turns instead of 100 turns to 200 turns? I don't think that is the case.
Again, a most basic guide would be good, one that assumes no losses, etc is fine.
Well, there's still going to be maths but the PDF (Part 3, chapter 14) gives you some good transformer design concepts.
http://ecee.colorado.edu/~pwrelect/book/slides/slidedir.html"
Edit: After rereading your post, maybe this chapter is a bit complicated?
haha, yea I actually find those slides when google searching, but they seem a little too complicated for me (I'm a M.E.). I was hoping for some really basic design slides.
An analogy in fluid mechanics would be to assume no losses with the fluid being isentropic, you can start with that, and then later fine tune your solution to take into account viscous drag, etc etc.
So far the best I've found is this, with regard to basic design.
http://ludens.cl/Electron/Magnet.html
I think I might have figured out my problem is though. Perhaps I will post later as to what the problem is, and what I think the solution is and why.
Thanks for your help.
The wikipedia page on transformers is a reasonable intro:
http://en.wikipedia.org/wiki/Transformer
As for the number of turns, you need enough turns for the magnetizing inductance to present a reasonable impedance to the driving voltage source, and you don't want so many turns that the wire resistance or the leakage inductance or the winding capacitance become large and obnoxious.
Transformer design is an art as much as a science. Between keeping up with materials, processes, cost, and the fundamentals, you're better off finding a designer. I live in the Dallas area, and there's a thriving community of these guys. I suspect any land of invention will have some transformer houses.
You can refer "transformer design.." book.
By M.G.Say.its very nice book.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
