Calculate Length of Transmitting Antenna for 1.8 GHz Frequency
  • Thread starter Thread starter XodoX
    Antenna
To calculate the length of a monopole antenna for a frequency of 1.8 GHz, the wavelength (λ) is determined using the formula λ = c/f, where c is the speed of light (approximately 2.99792458 × 10^8 m/s). The frequency f is 1.8 GHz, which equals 1.8 × 10^9 Hz. The calculated wavelength is about 16.67 cm, and the monopole antenna length is typically a quarter of this wavelength, resulting in a length of approximately 4.17 cm. Converting the speed of light to cm/s can simplify calculations for those unfamiliar with metric units.
XodoX
Hello, I got the following problem.
1. Assuming that your cell-phone antenna acts like a monopole, how long should it be if the
cell phone operates at a frequency of 1.8 GHz? (Note: 1 GHz = 1000 MHz =
1,000,000,000 Hz.)
2. λ= c/f
f would 1/T, T being the Hz. But that would be 0,0000000001
Then, c is always the same value, right? Which would be c = 2.99792458 × 108 [m/s].
I can't get the result. It's supposed to be about 4 cm:confused:
Hello XodoX! :smile:
Convert c to cm/s :wink:
