Trig - Help with tan(arccos(x/3))
  • Thread starter Thread starter TKDKicker89
    Trig
To solve tan(arccos(x/3)), first define theta as arccos(x/3). Construct a right triangle where the adjacent side is x and the hypotenuse is 3. Use the Pythagorean theorem to determine the opposite side, allowing the calculation of sin(theta). The tangent can then be expressed as sin(theta)/cos(theta). This approach effectively simplifies the problem using trigonometric identities.
TKDKicker89
Can anyone help asap?
tan(arccos x/3)
THanks
Draw a right triangle. If arccos x/3 = theta, draw that triangle.
if \theta=cos^{-1} \frac{x}{3}
then \frac{x}{3} is the cosine of \theta
You can use the pythagorean theorem to find the sine of \theta
\cos^2 \theta + \sin^2 \theta = 1
The tangent of \theta is \frac{sin \theta}{cos \theta}
