Integrating a Tricky Devil: $\int \frac{\cos^5(\theta)}{\sin^4(\theta)} d\theta$
  • Thread starter Thread starter gazzo
    Integrating
The integral $\int \frac{\cos^5(\theta)}{\sin^4(\theta)} d\theta$ can be approached by rewriting it as $\int \cot^4(\theta) \cos(\theta) d\theta$. A suggested method involves using trigonometric identities, specifically expressing $\cos^5(\theta)$ as $\cos^4(\theta) \cos(\theta)$ and substituting with $d(\sin(\theta))$. This leads to simplifying the numerator and integrating each resulting term separately. The discussion emphasizes the importance of manipulating the integral to make it more manageable.
gazzo
<br /> \int \frac{\cos^5(\theta)}{\sin^4(\theta)} d\theta<br />
Anyone mind sparing a little hint for this tricky devil? I can't even get started on it. \cot^4(\theta)\cos(\theta) dosn't seem any better either.
I've tried using identities but I end up with nastier ones?
this is an easy one :
cos^5(\theta)d \theta = cos^4(\theta)cos(\theta) d \theta = (1-sin^2(\theta))^2d(sin(\theta))
Fill this into the fraction and just work out the square in the numerator and integrate each part of the sum seperatly. If you want you can replace each sine by a dummy variable u but that is not necessary
marlon
oooh yes of course!
Thank you very much.
