Finding Coefficients in Trigonometric Functions
  • Thread starter Bob19
In summary, to find the coefficients A, B, C, and D in the given Trigonometry function, we can use the derivative F'(x) = x cos(x) and set up a system of equations using the rearranged form of F'(x). From this, we can determine that A = 0, B = C = 1, and D = 0.
Bob19
71
Hi
I have this here Trigonometri function:
F(x) = Ax cos(x) + Bx sin(x) + C cos(x) + D sin(x)
where F'(x) = x cos(x)
I'm suppose to find A, B, C , D any hints or idears on how I do that?
Sincerely
Bob
Take the derivative of F(x). You know that F'(x)=x cos(x). This means the coefficient of (x cos(x)) should be 1. What can you say about the coefficients of all other terms?
Since its trigonometry then A,B,C,D can't higher than one?
F'(x) = A (cos(x) - x *sin(x)) + B(x *cos(x) + sin(x)) + C ( -sin(x)) + D(cos(x) = x cos(x)
But how I proced from here ?
/Bob
No, these are just coefficients so they can be higher than 1.
It's cos(a) (and sin(a))) which are bounded between -1 and 1.
Your derivative seems correct, now just check what the coefficients have to be to get xcos(x).
The best way of doing this is that to make the left side of the expression shorter ?
/Bob
Well, we have:
[tex]\begin{array}{l}
F\left( x \right) = Ax\cos x + Bx\sin x + C\cos x + D\sin x \\
F'\left( x \right) = A\left( {\cos x - x\sin x} \right) + B\left( {\sin x + x\cos x} \right) - C\sin x + D\cos x \\
\end{array}[/tex]
Rearranging gives:
[tex]F'\left( x \right) = \left( {A + D} \right)\cos x + \left( {B - C} \right)\sin x - Ax\sin x + Bx\cos x[/tex]
We want this to equal [itex]F'\left( x \right) = x\cos x[/itex]
So:
[tex]\left( {A + D} \right)\cos x + \left( {B - C} \right)\sin x - Ax\sin x + Bx\cos x = x\cos x[/tex]
That should give a very simple system for the unknown coefficients A -> D
TD said:
Well, we have:
\end{array}[/tex]
Rearranging gives:
So:
Thanks then A = 0 , D = 0, B = C = 1
Right ?
/Bob
1. What is Trigonometry?
Trigonometry is a branch of mathematics that deals with the relationships between the sides and angles of triangles.
2. Why is Trigonometry important?
Trigonometry is important because it has many real-world applications, such as in engineering, astronomy, navigation, and surveying. It also helps to solve problems involving triangles and other shapes.
3. What are the basic trigonometric functions?
The basic trigonometric functions are sine, cosine, and tangent. They represent the ratios between the sides of a right triangle.
4. How do you use Trigonometry to solve problems?
To solve problems using Trigonometry, you need to use the relationships between the sides and angles of a triangle, along with the basic trigonometric functions. You can then use these functions to calculate missing sides or angles in a triangle.
5. What are some common applications of Trigonometry?
Trigonometry has many applications in fields such as engineering, physics, and architecture. It is used to calculate distances, heights, and angles in real-world situations. It is also used in computer graphics, where it helps to create realistic 3D images.
