Triple integral in cylindrical/spherical
frozenguy
Use cylindrical coordinates to find the volume of the solid.
The solid is enclosed by the paraboloid z=x2+y2 and the plane z=9
z=r2
So I'm getting close to the answer but not quite, and I keep getting a negative which doesn't make sense. And I think my limit on the second integration needs to be a function of theta.
I chose z=9 as my z upper limit and z=r2 as my lower and just used rdzdrd(theta) as my integrand. Used 0 for lower limit for both dr and dtheta and started to use sqrt(9/2) as my upper limits for both dr and d(theta) but then changed d(theta's) upper limit to 2pi.
I need help lol.
BTW.. My notation on this is sloppy. I originally started with the z limits reversed but changed it once I integrated.. sorry.
I believe you have the limits for z reversed, and the limits for r should be 0 and 3.
I thought I would mention that there is a simple way to solve this problem by considering the total volume of the cylinder with radius R=3 and height H=9 and then subtracting off the excess volume. The excess volume can be expressed as an area spun around the z axis, and the result is very simple as follows.
V=2\pi R^2 H - 2 \pi \int_0^R f(x) x dx =81\pi-2\pi \int_0^3 x^3 dx ={{81 \pi}\over{2}
Little tricks like this can save time, or provide a way to check your answer when you are required to demonstrate your ability to do the triple integral.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
