Finding Components of Cross Product for Vectors A and B
To find the components of the cross product for vectors A (3.5i + 1.8j) and B (1.7i + 4.8j), the correct approach involves using the determinant method. The cross product can be calculated using the determinant of a matrix formed by the unit vectors i, j, k and the components of vectors A and B. The resulting vector will have components that are orthogonal to both A and B, with specific rules for multiplying the unit vectors (i x j = k, etc.). The initial attempts to use the magnitude formula and separate component calculations were incorrect, as the problem requires the full vector form. Understanding the determinant method is crucial for obtaining the correct i, j, and k components of the cross product.
angel120
Vector A = 3.5i + 1.8j and vector B = 1.7i + 4.8j . Find the components of A x B:
AxB = AB sin(theta)
Since vector A=3.5i+1.8j and B=1.7i+4.8j, I translated that into vectors. So, A is 3.94 @ 27.77*, and B is 5.09 @ 70.56*. This means that the angle between A and B is 42.79*.
Using the AxB formula, I have 13.62. However, the problem (it's on WebAssign) wants the i, j, and k components.
I tried the AxB formula with the individual i and j components, and I got 4.04 for the i direction, and 5.87 for the j direction. However, they're both wrong, and I have no idea how to find out the k direction...
Help!
Thanks in advance,
-Angel.
k is the third dimesion (or 3rd component in this case). A and B are 2 dimensions.
I understand that the i, j, and k components are the x, y, and z directions, respectively. My frustration is that I believe I'm following the correct formula, but I still get the wrong answer. Where is my reasoning flawed?
I have tried the following:
AxB = (3.94)(5.09)sin(42.79) = 13.62, however, WebAssign wants the answer in components.
So, I tried this:
AxB = (3.5i)(1.7i)sin(42.79) = 4.04i
and then
AxB = (1.8)(4.8)sin(42.79) = 5.87j
When I entered these two (out of three) answers, they were both marked wrong.
The formula you try to use is for the magnitude of the vector axb, but the question asks for the vector itself.
Do you know the way to calculate a cross product as if it were a determinant?
axb=|i j k; a_i a_j a_k; b_i b_j b_k|
When you cross two vectors the resultant vector will be orthogonal to both original vectors. Keep that in mind.
You can multiply by components, but:
i x i=0 (same for j x j)
i x j =k
j x i = -k
Try this.
Newer mind the sin. Multiply the two vectors as you'll do for two binomials.
