How do I calculate the work done while climbing stairs?
  • Thread starter Thread starter weasal1975
    Power Work
To calculate the work done while climbing stairs, use the formula for gravitational potential energy, which is W = mgh, where m is mass, g is the acceleration due to gravity (approximately 9.81 m/s²), and h is the height gained. Given the mass of 77 kg and a vertical height derived from the distance climbed, you can determine the work done against gravity. The time taken to climb the stairs is not directly needed for this calculation. This approach simplifies the process by focusing on potential energy rather than forces and angles. Understanding this concept allows for an accurate calculation of the work done while ascending stairs.
weasal1975
I am working on a lab and I'm not sure how to calculate the work (done by me).
I know work = W=(F Cos theta) and Force =F= W/t
In the lab I am to walk up a set of stairs and time myself. I did this and got the following:
t=8 sec
d=6m
Mass(me)= 77kg
how do I find W?
Any pointer is greatly appreciated. I know I'm making this harder than it has to be I'm sure.
I assume that by 'weight', you mean weight in the layman sense and actually mean mass, given that your units are in kilograms. (Wow, 374kg's quite a bit)
Anyway, the work done by you (against gravity) is simply the increase in (gravitational) potential energy of your body, without having to re-derive and consider forces and direction and whatnot (which may not be very intuitive in such a scenario of climbing stairs).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
