TThermodynamics-compressed flow in a nozzle equation derivation
The discussion focuses on deriving the equation for compressed flow in a nozzle, specifically the relationship A/A* = 1/M[2/(k+1)(1+(k-1)/2*M^2)]^(k+1/2(k-1)). Participants highlight the importance of continuity equations and relationships involving Mach number, specific heat ratio, and temperature ratios. A key suggestion involves substituting various equations to relate Vstar/V and rhostar/rho back into the continuity equation. The conversation emphasizes the need for careful manipulation of equations to achieve the correct derivation. The thread concludes with encouragement to persist in simplifying the equations for a successful outcome.
luk3tm
Hi everyone!
Just one part of the lecture notes I couldn't work out how to derrive (apparently we need to know how).
A/A*=1/M[2/(k+1)(1+(k-1)/2*M^2)]^(k+1/2(k-1))
ρ0/ρ=[1+(k-1/2)*M^2]^(1/k-1)
To/T=1+(k-2/2)*M^2
Po/P=[1+(k-2/2)*M^2]^(k/k-1)
ρ*A*v*=ρAv
M=V/C (mach number)
c=√(KRT)
I tried fiddling around with quite a few things but got nothing.
Thanks!
Hint:
rho*A*V = rhostar*Astar*Vstar (continuity)
A/Astar = rhostar*Vstar/(rho*V)
Relate Vstar/V to mach number and specific heat ratio by using supplemental equations below
Relate rhostar/rho to mach number and specific ratio by using supplemental equations below
Supplemental equations:
T0/T =1 + (k-1)/2)M^2
Tstar/T0 = 2/(k+1)
0 subscript denotes stagnation condition
okay so i think I've almost got it but i might be missing out on something:
Vstar/V=Ap/Astar*pstar
substituting in mac number,
Mcstar/Mcr=RHS
substituting C=sqrt(KRT)
gives:
M/Msqrt(KRTstar/KRT)
=sqrt(T*/T)
Tstar/T=Tstar/To*To/T=(1+k-1/2)M*2*2/k+1
and pstar/p=po/p*pstar/po=(2/k+1)^1/(k-1)*(1+k-1/2*M^2)*1/k-1
so back to original equation:
A/Astar=sqrt(Tstar/T)*pstar/p
sqrt((1+k-1/2)M*2*2/k+1)*(2/k+1)^1/(k-1)*(1+k-1/2*M^2)*1/k-1
which doesn't quite give the right answer :(
Derive an expression for Vstar/V that you'll eventually plug into the continuity equation. After substituting Vstar=Cstar=sqrt(kRTstar) and also noting that V=C*M=M*sqrt(kRT) you should arrive at
Vstar/V = (1/M) * sqrt(Tstar/T)
Now write as
Vstar/V = (1/M)*sqrt(Tstar/T0)*sqrt(T0/T)
But Tstar/T0 = 2/(k + 1) and T0/T = 1 + (k-1)*M^2/2
Substitute these in then use a similar tactic for rhostar/rho.
Plug both into continuity equation and simplify. It'll work...
