Two basic types of horizontal stabilizer systems
The discussion revolves around the types of horizontal stabilizer systems used in general aviation aircraft, specifically comparing horizontal stabilizers with elevators to stabilators. Participants explore the effectiveness, cost, and design considerations of these systems, particularly in the context of an experimental tailwheel aircraft.
  • Some participants note that stabilators are generally considered more effective but question why many aircraft still use traditional horizontal stabilizers with elevators.
  • Cost is proposed as a significant factor, with elevators being adequate for most flight conditions and simpler to service, thus reducing overall expenses.
  • Concerns are raised about stabilators lacking force feedback to the pilot, necessitating additional components like anti-servo tabs or computer systems for stability.
  • One participant seeks clarification on the function of anti-servo tabs, suggesting they may require complex calculations for proper feedback force.
  • Another participant distinguishes between servo tabs and anti-servo tabs, explaining their differing effects on control forces and the implications for aircraft design.
  • There is a mention of the potential for stabilators to stall if moved too far, which could lead to a sudden loss of control force.
Participants express multiple competing views regarding the advantages and disadvantages of stabilators versus elevators, with no consensus reached on the best approach for the experimental aircraft.
Participants discuss various design considerations and operational implications, but the conversation does not resolve the complexities involved in choosing between stabilator and elevator systems.
Warren Hubbard
There are two basic types of horizontal stabilizer systems on most general aviation aircraft. Horizontal stabilizer with elevator, and or horizontal stabilator. If the horizontal stabilator system that is on most piper aircraft and some high performance fighter aircraft, then why are so many tailwheel and other aircraft designed with the horizontal stabs and elevator. Stabilator systems are supposed to be more effective and generally better by design. I am seeking opinions for an experimental aircraft that I am working on. It will be a tailwheel type aircraft.
I imagine it has a great deal to do with cost. Elevators do the job perfectly adequately for the flight conditions of most aircraft (which basically just try to maintain stable flight paths, rather than maneuver), so it's not worth the added cost to design them with stabilators. Elevators are also much simpler to service, so there's reduced cost and reduced risk there.
Another issue is that stabilators tend to have no force feedback to the pilot controls (the stabillator pivots about its aerodynamic center of pressure), so either you need another component like an "anti-servo tab" to provide some feedback force to the pilot (which is a requirement for aircraft certification), and/or a computer system to maintain the aircraft stability in hands-off flight.
Elevators are intrinsically stable, as well as being simpler and probably cheaper.
With that said, would I be correct in assuming the anti servo tab would be a spring tab? And if that is correct, it would take someone smarter than myself to figure the spring force to provide that correct feed back pressure. Not only the design is costly, but the upkeep to insure proper function is provided could be a potential problem. The fact that piper had these on their general aviation trainer's is a surprise. In my flight instructing days I just moved them up and down on preflight to make sure they were moving in the right direction, I didn't take into account the engineering that went along with them. Thanks guys for the input.
I don't know the specifics of the Cessna design, but don't confuse servo tabs and anti-servo tabs.
A servo tab reduces the pilot control force by providing "power assistance" to move the main tab. In the simplest version, the plot controls only move the servo tab at the rear of the main tab, and the aerodynamic forces on the servo tab then move the main control surface. There is a damper to stop the system oscillating, but otherwise the main control surface is free to move where it wants to.
That simple idea has the problem that the amount of servo effect varies with the air speed, and the mechanical spring of the "spring tab" reduces that variation.
An anti-servo tab works in the opposite way to increase the control force. I would imagine there is a mechanical linkage between the tab and the servo, so the servo is forced to turn through a bigger angle than the main tab in the same direction, not the opposite direction like a servo tab.
Stabiliators are lighter and provide more control force for a given size compared with an elevator - unless you move them too far and they stall, when the control force suddenly disappears!
  • · Replies 31 ·
15K
  • Poll Poll
