Two charges are placed at the corners of a square
  • Thread starter Thread starter remchu123
    Charges Square
Two charges, 4.0μC and -6.0μC, are placed at opposite corners of a square, and the goal is to determine the charge needed at the center to achieve zero potential difference at the other corners. The total electric potential is expressed as Vtot = V1 + V2 + V3, where V1 and V2 are from the fixed charges and V3 is from the unknown charge at the center. A user initially calculated the required charge as -2.8 x 10^-6 C but later realized the correct value should be -1.4 x 10^-6 C due to a misunderstanding of the distance formula. The discussion emphasizes the importance of correctly applying the distance in the potential equation. Understanding these concepts is crucial for solving similar physics problems effectively.
remchu123
Electric Potential !
Two charges are placed at the corners of a square. One charge, 4.0μC, is fixed to one corner and another, -6.0μC, is fixed to the opposite corner. What charge would need to be placed at the intersection of the diagonals of the square in order to make the potential difference zero at each of the two unoccupied corners?
V= kq /r
Vtot = V1 + V2 + V3
but then i realized that 3rd charge is unknown where it is, i just don't know how i should approach this problem? help. =[
welcome to pf!
hi remchu123! welcome to pf! :wink:
call the 3rd charge (the one in the centre) q, then proceed as usual …
show us what you get :smile:
V= kq /r
Vtot = V1 + V2 + V3
Hello remchu123 . Welcome to PF !
That's why there are variables.
Let the charge at the center have a charge of Q or q.
V1 + V2 + V3 =0
kq1 /d + kq2 /d + kq3 /d (route)2 over 2= 0
then i solved for q3 and i got -2.8x 10^-6 C
but the answer is -1.4 x 10^-6C
which means i forgot half somewhere..
thanks though! i think i can handle it!
wish me luck in physics 12 exam tomorrow! ahha
i'll very likely need all of your "ki"s ( DBZ reference? lol)
hi hremchu123!:smile:
(btw, it's "root" not "route" :wink:)
you just got confused about the distance …
it's d/√2, not d√2 :wink:
