Two closely related questions about current density
JFuld
*The problem statement
The second question kinda builds on the first and I am not too confident my solution to the first is correct.
1: A disk has a uniform surface charge density and is rotated at a rate 'w'. Find 'K'.
2: A uniformly charged sphere ('ρ') is spun. Find the current density.
*Relevant equations
K=surface current density = σ*v
J = volume current density = ρ*v
*The attempt at a solution
1: ω= the linear (tangental?) velocity of a point on this disk / radius, so v=wr
then K = ωr*σ , and is oriented in the ∅ direction
2: for a spinning sphere, the velocity of the charge is the same as above except v=0 on the axis of rotation for any r.
so if i let the z axis be the axis of rotation, and let r = r(cos∅+sin∅), and v=wr(cos∅+sin∅)
then J = ρwr(cos∅+sin∅), oriented in ∅ direction
yea that's my attempt at the solution. I think my answers make sense, but most homework problems I am assigned require more than 2 lines of work so it is not unlikley that i am missing something.
thanks in advance for any help
*Relevant equations
That's correct.
The speed of a point in the sphere depends on its distance from the axis of rotation. If the axis of rotation is the z-axis, what's the distance of a point (r, θ, φ) from the z-axis?
Kind of a strange question.
The current di passing by an arbitrary elemental radial length dr at r, 0 < r < R is
di = σrω dr
so the corresponding elemental current crossing dr is a function of r
and the only meaning for current density must be the current per unit radial length, or
di/dr = σrω which has units of current per unit length.
The total current is i = ∫di = σω∫r dr from 0 to R = σω(R^2)/2 so you could say an average current density is σω(R^2)/2R = σωR/2. The last also has units of current per unit length, the same units as the OP's "K".
But really current density varies from 0 to σωR as we go from the center (r=0) to the edge (r=R) of the disk.
I won't even try for the 2nd part.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
