Two Point Charges Net Electric Field
The discussion focuses on calculating the net electric field at two points due to two point charges: -2.5 µC at the origin and +8.5 µC at x = 10.0 cm. The user attempts to compute the electric field at x = +4 cm and x = -4 cm using the formula E = kq/r^2 but arrives at incorrect values. They express confusion over the correct approach, particularly regarding the addition of electric fields from both charges. The correct net electric field at x = +4 is ultimately stated to be 3.5 x 10^7 N/C after considering significant figures, but the user continues to receive feedback indicating their answer is incorrect. Clarification on the calculation method and proper sign conventions is needed for accurate results.
Octoshark
Two point charges lie on the x axis. A charge of -2.5 µC is at the origin, and a charge of +8.5 µC is at x = 10.0 cm.
What is the net electrical field at points x = +4 and at x = -4?
E = kq/r^2
For x = +4...
E= 9x10^9(8.5x10^-6)/.06^2 = 21250000
E= 9x10^9(-2.5x10^-6)/.04^2 = -14062500
Net E = 7187500 (which is wrong)
How do I solve this? Thanks.
use absolute values for charges and then add/subtract them up qualitatively.
the -2.5uC will make the E field LARGER at point x=+4 so you would add it instead of subtract.
That didn't work.
I'm pretty sure it should work. What's the correct answer for both positions?
It doesn't give me the right answer until I submit the right answer. I entered 35312500 for x = +4 and it says that is incorrect. (I submit the answers online)
the answer is 3.5*10^7 after sig figs.
It says that is wrong too
