Ultrasonic crack detection in glass bottles
The discussion centers on developing a vision-based machine for detecting cracks in glass bottles at a bottling plant, highlighting the challenges posed by the bottle's shape. While the standard vision and backlight method is common, it may be costly and complex due to the bottle's design. An alternative ultrasonic crack detection method is proposed, suggesting that cracks could alter the bottle's resonant frequency, allowing for detection through sound analysis. The conversation also notes that effective inspection may require multiple cameras or a rotating turntable to examine all sides of the bottle. Overall, the exploration of ultrasonic methods presents a potential solution to the limitations of traditional vision systems.
dc878787
I'm working on a project for a bottling plant that is trying to make a vision-based machine to detect cracked glass bottles before they attempt to fill them.
It seems that the vision & backlight approach is the standard way to do this in the industry, but the shape of the bottle in this application makes this a tricky/expensive machine.
I'm wondering if anyone has any experience with some type of ultrasonic crack detection methodology? I'm just going on a hunch here, but I think that at least some cracks should change the resonate frequency of a bottle enough to detect the change..
Can you provide a pic of the bottle's shape?
Shows a lot of flaws --- laser plus beam expander (cylindrical lens in front of laser level light source) and a diode array looking for reflections, or reduced transmission.
Support a bottle by one point, say by the cap, then tap the bottle so it rings like a bell at a fundamental frequency. If there is a fracture in a bottle it will sound dull and generate a short burst of harmonics of the fundamental frequency. I expect the harmonics generated to be even because the crack opens for part of the cycle but is closed on the other half cycle. With a good bottle the ringing will continue for longer at the fundamental frequency and there will be less 2'nd harmonic generated.
Likes timthereaper and berkeman
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
