Uncertainty in the position of a particle, and momentum question
Zit501
Hi all,
I just can't wrap my head around this one. It should be fairly easy, but I'm lost!
Suppose that the uncertainty in the position of a particle is of the order of its de Broglie wavelength. Show that in this case the uncertainty in its momentum is of the order of it's momentum.
Not 100% sure...
Delta x is similar to the wavelength
Delta p is similar to Plancks constant over wavelength
Therefore delta x delta p are similar to Plancks constant
Well I can see how delta x and delta p can be related together to the wavelength, but after that I'm lost.
Any help much appreciated! I'm a B.Sc Mechanical Engineer doing an entry level nuclear physics course and I'm holding on... just.
Yes, so you almost got it.
\Delta x \sim \lambda
If the uncertainty relation is near the minimum value, then
\Delta x \Delta p \sim \hbar
So what is \Delta p then. What is \lambda in terms of p?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
