Understanding Eigenvectors: Troubleshooting and Verification
awl2k
Hello people!
I am having a bit trouble with verifying my result when i compute the eigenvectors for the following matrix:
A=[[3,4],[3,2]]
I know for sure that the eigenvalues is respectively -1 and 6, so i start finding a solution for the following null spaces:
1) N(A--1I)=[[4,4|0],[3,3|0]]~[[1,1|0],[0,0|0]] => x1 = x2 so the the vector x2[1,-1] will be a solution and therefor the first eigenvector is [1,-1]
2) N(A-6I)=[[-3,4|0],[3,-4|0]]~[[1,-4/3|0],[0,0|0]] => x1=4/3 so this indicate that x2[-4/3,1] will be a solution to the null space, and therefor the second eigen vector i [-4/3,1].
However the result should be [1,-1] [4,3] respectively. What am i doing wrong?
[-4/3,1] is not an eigenvector of 6. The correct eigenvector is [4/3,1] because the equation you get is 3x-4y=0.
Eigenvectors are always undermined up to a multiplicative factor, since if A*x = λ*x, then
A*(nx) = λ*(nx). So (4/3,1) and (4,3) are the same eigenvector.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
