Understanding Limits: Why |h|/h Approaches -1 as h Approaches 0
  • Thread starter Thread starter ratios
    Limit
ratios
Hello all,
I don't understand why |h|/h will become -1 as h approches 0 from the left. I can see how the numerator becomes negative, as |x| = -x if x< 0, but shouldn't the denominator become negative also since h < 0 when we approach 0 from the left? So why isn't the answer -h/-h = 1?
The numerator is always positive. It's true that |x|=-x when x<0, but in that case -x>0, and |x|/x=-x/x=-1.
You see wrong. Here, -x is positive.
Okay I see. Thanks for the help!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
