JC2000
- 186
- 16
- TL;DR Summary
- I would be grateful if you could check my understanding of the base emitter voltage for a BJT.
##V_{BE}## is basically the difference in voltage between the base terminal and the emitter terminal.
Normally when silicon is used and the transistor is biased to operate in the active region, ##V_{BE}## = 0.7 V approximately.
The way I understand this is that for an npn BJT, the applied voltage must be at least 0.7 to ensure that the depletion barrier is overcome by the forward bias.
The way this 0.7 V is applied is by connecting a resistor in series with the source voltage (##V_{BB}##) so that there is a voltage drop.
The reason ##V_{BE}## is always around this 0.7 V value and not much more is because the input characteristics of the common emitter BJT suggest that even for a small voltage increase at this point, the spike in current would be large enough so that the power dissipated would damage the device.
Is this reasoning correct?
