Uniform electric field. Find the potential difference
To find the potential difference Va-Vb between points A and B in a uniform electric field E=(4i+3j) N/C, the relationship between electric field and potential must be understood. The potential difference can be calculated using the formula ΔV = -∫E·dl, where dl is the differential displacement along the path from A to B. The uniform field implies that the potential difference is dependent only on the coordinates of points A and B. The discussion emphasizes the need to relate the electric field to the potential energy required to move a charge within that field. Understanding this relationship is crucial for solving the problem effectively.
Bearbull24.5
Point A (2,3)m and point B (5,7)m are in a region where electric field is uniform and given by E=(4i+3j)N/C. What is potential diff Va-Vb?
Not a clue
I tried converting the (4i+3j) into magnitude and that is as far as I got. Not a clue what to do next
Not a clue
How is the electric field related to the potential?
Isnt the potential the energy required to move a charge in an electric field?
It is indeed. So how does that relate to your problem?
