Uniform electric field moving a proton and electron
A uniform electric field of 640 N/C exists between two parallel plates, with a proton released from the positive plate and an electron from the negative plate. The equations of motion for both particles were set up to find the point where they would meet, but the calculations revealed discrepancies in their positions. The key confusion arose from the fact that while both particles experience the same electric field, their differing masses lead to unequal accelerations. The correct approach is to consider that the sum of the distances they travel must equal the distance between the plates, rather than assuming they meet at the same point. The discussion highlights the importance of understanding the relationship between force, mass, and acceleration in electric fields.
gsquare567
A uniform electric field of magnitude 640 N/C exists between two parallel plates that are 4.00 cm apart. A proton is released from the positive plate at the same instand that an electron is released from the negative plate. Determine the distance from the positive plate that the two pass each other. (Ignore the electrostatic attraction between the proton and electron.)
r = 0.04 m
E = 640 N/C
qp = 1.6 * 10-19 C
qe = -1.6 * 10-19 C
mp = 1.67 * 10-27 kg
me = 1/1830 * mp
[1] x = x0 + v0 + 1/2*a*t2
[2] F = ma = qE
PROTON:
using [2], a = qp*E/mp
subbing into [1], xp = 1/2(qp*E/mp)t2
ELECTRON:
xe = r + 1/2(qe*E/me)t2
see when xp = xe
t = \sqrt{2*r/(E(q<sub>p</sub>/m<sub>p</sub> - q<sub>e</sub>/m<sub>e</sub>}
i get t = 2.67 * 10-8 seconds
but when i plug it in for xp i get 2.18*10-5 m, whereas xe is 4.00 * 10-2 m
they should be equal =S
where did i go wrong? thanks! :smile:
Should they be equal? Does equal force imply equal acceleration in this case?
I thought they would be different because a proton has 1830 times the mass of an electron, and as F = m * a... Am I wrong?
No, no, you're right in that. They won't meet in the middle, though, because they've been accelerated unequally. You want not xp = xe, but xp + xe = 4.
Oh, I understand what you mean now. However, they are released from opposite ends, so I think when they cross, their x values should be equal. That is why my x equation for the electron starts at r = 4.
If one particle starts at 0, and the other at r = 4, then one will accelerate in the positive r direction, and the other will accelerate in the negative x direction.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
