Uniformly Distribution Problem
  • Thread starter Thread starter Askhwhelp
    Distribution
Askhwhelp
A random variable X drawn from a uniform [0,3] distribution and a random variable y is independently drawn randomly drawn from a uniform [0,4] distribution. The joint probability density f(x,y) is also uniform, with support given by 0 ≤ x ≤ 3, 0 ≤ y ≤ 4. Find the probability for the sum of two randomly selected number is 3
This should be 0 because a line does not have any area, right?
Find the probability for the sum of two randomly selected number greater than 3
12-4.5 = 7.5/12 = .625, right?
12-4.5 = 7.5, right?
Show your work.
ray vickson said:
show your work.
3*4 - p(y<=3) = 12 - 3*3/2 = 12-4.5= 7.5/12 = .625
Please check it thx
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
