Designing & Engineering Variable Pitch Turbochargers
The discussion focuses on designing a variable pitch turbocharger to enhance flow regulation on both the hot and compressor sides. The aim is to create a system that eliminates overboost and overpressure, making it suitable for a wider range of engine sizes. The proposed design incorporates Variable Nozzle Turbines (VNT) or Variable Geometry Turbines (VGT) to improve efficiency and performance. Key challenges addressed include the passive nature of traditional turbochargers and the need for effective pressure management. The goal is to develop a universal turbocharger that optimizes air and exhaust flow for better engine performance.
NintendoKD
I want to design build and overall engineer a variable pitch turbocharger. This will go a long way in regulating both the hot and compressor sides flow rates, a larger turbo can essentially be used in smaller applications, and vice-versa. I want to use the VNT or VGT type turbos for my testbed.
cool. i actually just read about turbochargers (TC).
my concern is that a TC is a passive device. what would you do differently from traditional TCs?
let me know how this works out. are you going to put out a writeup?
The general operation of a turbocharger is that it uses hot exhaust gasses expelled from the motor to turn a turbine "hot side" the compressor, connected by a shaft draws in air and forces it into the intake, sometimes cooling it down via an intercooler. This process is usually known as "forced induction" The turbocharger faces many challenges, two of which are overboost and overpressure, as well as having to depend on a given size of compressor/turbine for a specific engine displacement/output. The reason for this, is that at high rpm/top of the powerband, such as when the transmission will shift to the next gear, the large intake caused by the compressor taking in a lot of air for high demand/high rpm's has no where to go and is unneeded at lower rpms, this is also dangerous for the engine, as the tubo also acts as a one way valve, and prevents the pressure from going out the way it came, hence the necessity of the blowoff valve, which is now wasted boost vented to the atmosphere. I plan to prevent this waste and make a truly on demand system, by eliminating overboost and overpressure. Overpressure occurs when the similar process happens but instead on the exhaust side, to prevent the turbo from spinning too fast, or stopping altogether, "universally bad" This necessitates the BOV or blow off valve, to regulate the exhaust/turbine side of the turbo. the expended /unneeded exhaust is vented directly to the downpipe thereby bypassing the turbin and not pushing it to turn the compressor unneccessarily. A VNT or Variable Nozzle Turbine, or VGT, or Variable Geometry Turbine, does this quite well, and works well with small and large engines to a point. I want to create, however, a turbo that is nearly universal, or a supercharger that is universal, it will aid in efficiency, by changing the efficiency of the tubine/compressor wheels and the direction of flow for better mixture/vortex action, to aid in flow once again.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
