Solve Unwinding Ribbon Homework: Find Acceleration in Terms of m, R, g
  • Thread starter Thread starter postfan
The discussion focuses on finding the downward acceleration of a blue spool connected to a red spool via massless ribbons. The user initially applies Newton's second law and derives equations involving tension and acceleration but struggles with the torque equations for both spools. Feedback indicates that the torque equations are incorrect, particularly for the red spool, and emphasizes the need for distinct symbols for angular acceleration. A hint is provided to consider the relationship between angular and linear acceleration, suggesting a method to combine the effects of both spools. The conversation highlights the importance of correctly applying torque principles and understanding the dynamics of the system.
postfan
Red ribbon wound around a red spool (above) is taped to blue ribbon wound around a blue spool (below). The ribbon is essentially massless, but the solid cylindrical spools each have mass m and radius R. If the red spool can freely rotate on a fixed axle and the blue spool is positioned directly underneath with the ribbon taut, what is the downward acceleration of the blue spool? Gravity is downward.
Enter your answer in terms of some or all of the variables m, R and g.
Used F=ma and got mg-T=ma, a=(mg-T)/m, and kind of got stuck there.
Remember that both spools will rotate. Create variables for the two angular accelerations and write down torque equations. There's another equation relating these two angular accelerations to the blue spool's linear acceleration.
I came up with 2 torque equations:
(T-mg)*r=I*alpha (alpha is postive)
(mg-T)*r=I*alpha (alpha is negative)
Can you tell me if these are right or not, also can you give me a hint for the equation that relates angular to linear acceleration? Thanks!
Please use different symbols for different variables, e.g. αred, αblue.
Your torque equation for the red spool is wrong. Have another think.
It's just like the equation that relates angular velocity of a car wheel to the car's linear velocity, except that here you have two wheels affecting the length of ribbon. It might help to think first about the equation that would apply if the ribbon were stuck on the bottom reel so that it could not spin. How would the linear acceleration of the bottom spool relate to the angular acceleration of the top one? Then swap it around and suppose only the bottom spool can spin, then try to put the two together.
The torques are related to the tension in the ribbons, which is T (not (T-mg) or (mg-T)). Since the ribbons are massless, T is constant (not affected by height).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
