What is the Unknown Force Acting on a 2.8 kg Object in Upward Vertical Motion?
  • Thread starter Thread starter tdusffx
    Force Vertical
A 2.8 kg object in upward vertical motion experiences an unknown force in addition to its weight. The object, starting from rest, has a displacement of (4.2i - 3.3j) m in 1.2 seconds. To find the other force, the displacement is split into i and j components, and the total force is calculated using the object's acceleration. The weight force is then subtracted from the total force to determine the unknown force. The discussion highlights the importance of correctly handling signs in force calculations.
tdusffx
can anyone help me start this problem?
Besides its weight, a 2.8 kg object is subjected to one other constant force. The object starts from rest and in 1.2s experieces a displacement of (4.2i - 3.3j) m, where the direction of j is the upward vertical direction. determine the other force
Start by splitting the displacement into i and j components. Using the displacements calculate the total force on the object. Then subtract the weight force from the total force to get the 'other force'.
kk, I got...
deltaX = Vixt + 1/2at^2
4.2 = 0 1/2a(1.2)^2
a = 5.8i
deltaY = Viyt + 1/2at^2
-3.3 = 0 + 1/2a(1.2)^2
Y = -5.4j
F = 2.8kg(5.8i + 5.4j) ?
Seems roughly ok. I don't have to check your arithmetic, right? But aren't you losing signs again in the total force? Shouldn't the y component of the force be DOWN?
yup yup! you're right again, dick. Signs are always messing me up. Thanks again.
