Use Coulomb's Law to calculate the number of excess electrons
The problem involves calculating the number of excess electrons on a negatively charged object using Coulomb's Law, given the force between two charged objects and the excess charge on one of them.
  • The original poster attempts to calculate the excess charge and subsequently the number of excess electrons on the second object using Coulomb's Law. Some participants discuss the accuracy of calculations and the number of significant figures to maintain throughout the process.
Participants are engaged in discussing the calculations and the importance of maintaining significant figures. There is a focus on ensuring accuracy in the intermediate steps of the calculation, but no consensus on the final number of excess electrons has been reached.
The original poster specifies a requirement for two-digit accuracy in their final answer, which influences the discussion on significant figures.
dwach
Two negatively charged objects repel each other with a measured force of 6.3 N when they are 0.5 cm apart. If the excess charge on one of the objects is caused by 8.3 x 10^22 extra electrons, use Coulomb's Law to calculate the number of excess electrons on the second object.
F = k*(q1)*(q2) / r^2
1e = 1.602 * 10^-19 c
1c = 6.242 * 10^18 e
k = 9.0 * 10^9 N*m^2/c^2
I calculated the excess charge to be:
(8.3*10^22 e) * (1.602 *10^-19) = 1.3 * 10^4 c
I used this as q2 in the F = k*(q1)*(q2) / r^2 equation and rearranged to find that:
q1 = (F * r^2) / k*q2
q1 = (6.3N * 0.005m^2) / (9.0*10^9N*m^2/c^2)*(1.3*10^4c)
q1 = 1.3 * 10^-18
Since 1c = 6.242*10^18e, to find number of excess electrons i multiplied q1 by 6.242*10^18 = 8.1146 eSo is the number of excess electrons on the second object 8.1 ?
Welcome to PF, dwach!
Your calc looks good, and thank you for taking time to write out the method so clearly. I don't know what accuracy you need; I'm used to 3 digits so I keep 4 in intermediate steps and I got 1.318 x 10^-18 for the charge, which is 8.24 electrons.
Thank you for the quick response Delphi51. In this question I need 2 digit accuracy so would you suggest that I carry 3 digits through the intermediate steps?
Yes, you must carry 3 digits to get 2 at the end. In practise, you probably will just keep all the digits your calculator produces for the first calc and only round when you write down the final answer.
