Use node-voltage method to find current?
  • Thread starter Thread starter Color_of_Cyan
    Current Method
The discussion focuses on using the node-voltage method to analyze a circuit and find branch currents Ia, Ib, and Ic, as well as the power associated with each source. The equations derived include relationships between voltages and currents across resistors, leading to the calculation of node voltages. The user confirms that Vb and Vc are equal, suggesting a simplification in labeling. The calculated branch currents are Ia = 2A, Ib = 4A, and Ic = 1A, with power calculations showing 100W and 120W supplied by the sources. The results appear consistent, indicating a successful application of the node-voltage method.
Color_of_Cyan
use "node-voltage" method to find current?
http://imageshack.us/a/img213/8582/homeworktest2prob1.jpg
a. Use the node-voltage method of circuit analysis to find the branch currents Ia, Ib, and Ic in the circuit
b. Find power associated with each source and state whether the source is delivering or absorbing power.
V = IR
Nodal analysis ?
P = IV
I assume it means nodal analysis, so:
http://imageshack.us/a/img594/8576/homeworktest2prob1edit.jpg
my equations starting are:
(Va - Vb)/5Ω = Ia
Vb/10Ω = Ib
Vc/40Ω = Ic
3A + Ia = Ib + Ic
Va = 50V and Vb = Vc right at the beginning
So:
3A + (Va - Vb)/5Ω = Vb/10Ω + Vb/40Ω
3A + (Va - Vb)/5Ω = (4Vb + Vb)/40Ω;
(then added (-Va + Vb)/5Ω to both sides and multiplied for common denominator:)
3A = (-8Va + 8Vb + 4Vb + Vb) / 40Ω
(substitute Va = 50V and combine like terms)
3A = (-400V + 13Vb)/40Ω
120V = -400V + 13Vb;
Vb = 520V/13
Vb = Vc = 40V
Ib = (40/10)A
Ib = 4A
Ic = 40/40A
Ic = 1A
Ia = -3A + 4A + 1A
Ia = 2A
P = IV
P from 50V = 2A*50V
= 100W supplied
P from 3A = 3A * 40V
= 120W supplied
Looks good or no?
and the power absorbed by the resistors adds up to the same amount
I did a quick check and got Ia = 2 so I figure you've got the rest right as well, but I didn't actually check any of them
It looks funny to have both Vb and Vc, since they are the same node. I'd just label it Vb.
