Using Ice Tables: When to Use X
  • Thread starter Thread starter merry
    Ice
The discussion centers on the appropriate use of an unknown variable (x) versus directly subtracting the concentration of the limiting reagent in chemical reactions. It clarifies that an unknown (x) is typically used when the change in concentration of reactants and products is not straightforward, often in cases where the reaction does not go to completion or when the limiting reagent's concentration significantly affects the equilibrium. In contrast, when the limiting reagent's concentration is low enough to be ignored in mass balance calculations, it can be subtracted directly from the initial concentrations of the reactants. This distinction is crucial for accurately modeling chemical reactions and understanding equilibrium shifts.
merry
When do you use an unknown (x) as the change in the concentration of the entities and when do you simply subtract the concentration of the limiting reagent from the initial concentration of the reactants? @.@
Thanks!
Chemistry news on Phys.org
I hope I understand your question correctly, it would be easier if you will give an example.
If you treat something as a limiting reagent it means that for some reason you assume equilibrium in the reaction is shifted so far to the right, that concentration of the limiting reagent in the mixture is so low, it can be ignored in mass balance.
methods
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
