Using node-voltage analytical technique
  • Thread starter Thread starter november1992
    Analytical
5 replies · 2K views · last reply
november1992
Calculate the voltage at each of the extraordinary nodes (V1 – V3), and the current through each of the six resistors.
http://i.imgur.com/VbZQH.png
KCL: ƩIn = 0
V=ir
I=[itex]A^{-1}[/itex]B
[itex]\Delta[/itex] = a11C11 + a12C12 + a13C13
[itex]A^{-1}[/itex] = [itex]\frac{adjA}{\Delta}[/itex]
adjA = [itex][C_{jk}]^{T}[/itex]
For I1+I2+I3=0:
[itex]\frac{V1-4}{0.2}[/itex] + [itex]\frac{V1-V2}{0.5}[/itex] + [itex]\frac{V1-2}{0.1}[/itex] = 0
For I4+I5+I6=0:
[itex]\frac{V2-V1}{0.5}[/itex] + [itex]\frac{V2-V3}{0.5}[/itex] + [itex]\frac{V2}{0.1}[/itex] = 0
For I7+I8+I9=0:
-[itex]\frac{V1-4}{0.2}[/itex] + [itex]\frac{V3-V2}{0.5}[/itex] + [itex]\frac{V3-3}{0.1}[/itex] = 0
([itex]\frac{1}{0.2}[/itex] + [itex]\frac{1}{0.5}[/itex] + [itex]\frac{1}{0.1}[/itex])V1 - ([itex]\frac{1}{0.2}[/itex] + [itex]\frac{1}{0.5}[/itex])V2 + 0V3 = 40
([itex]\frac{1}{0.5}[/itex]+[itex]\frac{1}{0.5}[/itex]+[itex]\frac{1}{0.1}[/itex])V2 - ([itex]\frac{1}{0.5}[/itex])V1 + (-[itex]\frac{1}{0.5}[/itex])V3 = 0
(-[itex]\frac{1}{0.2}[/itex])V1 + (-[itex]\frac{1}{0.5}[/itex])V2 + [itex]\frac{1}{0.5}[/itex] + [itex]\frac{1}{0.1}[/itex])V3 = 10
And then I simplified that to:
17V1 - 7V2 + 0V3 = 40
-2V1 + 14V2 -2V3 = 0
-5V1 - 2V2 + 12V3 = 10
My book says I should use Cramer's rule or matrix inversion to solve this. I chose to use matrix inversion because I thought solving a simultaneous equation would take a while.
I ended up with I1 = 2.627, I2 = 2/3, I3 = 2.039
That's obviously wrong since the sum should equal zero. I'm not sure what I did wrong, I just followed the steps in my book.
november1992 said:
For I1+I2+I3=0:
For I4+I5+I6=0:
For I7+I8+I9=0:
You must include the effect of V3 in this equation, as shown:
For I1+I2+I3=0:
[itex]\frac{V1-4-V3}{0.2}[/itex] + [itex]\frac{V1-V2}{0.5}[/itex] + [itex]\frac{V1-2}{0.1}[/itex] = 0
And this one:
For I7+I8+I9=0:
-[itex]\frac{V1-4-V3}{0.2}[/itex] + [itex]\frac{V3-V2}{0.5}[/itex] + [itex]\frac{V3-3}{0.1}[/itex] = 0
Okay, I redid my work and I'm still getting the wrong answer. In my previous post I mistakenly wrote my answers as current values instead of voltages sinceI'm calculating the voltages at the extraordinary nodes.
17V1 - 2V2 - 2V3 = 40
-2V1 - 2V2 + 17V3 = 50
After doing the matrix inversion, I ended up with V1 = 2.85556V, V2= 0.891089V and V3 = 3.3819V.
I built the circuit on my computer and I got v1 = 2.8693V, v2 = 0.625V , v3 = 1.5057V
EDIT:
I messed up on my calculations above. I'll re-do them again.
EDIT:
You haven't done your algebra right. You should have:
17V1 - 2V2 - 5V3 = 40
-5V1 - 2V2 + 17V3 = 10
Yeah, I realized that after I posted. I got the correct values now, thanks for the help.
What confused me was the top part of the circuit, specifically the 4V source between the two extraordinary nodes. When I look at circuit diagrams I usually make the mistake of assuming the corners are all nodes. So I treated the corner right above V2 as a node. I make a lot of careless mistakes.
