Using Quarter Wave Plate in Microscopy: Hanan's Question
  • Thread starter Thread starter hen
    Plate Wave
Using a quarter wave plate in microscopy can be done before the specimen, allowing for the illumination of birefringent samples with circularly polarized light, depending on the plate's orientation. While traditional setups place the plate after the specimen, placing it beforehand can still yield useful results. Some participants noted that using a laser as a light source enhances image quality but requires careful handling to avoid eye damage. Additionally, there is interest in creating or acquiring broadband zero-order quarter wave plates, with suggestions that layers of cellophane tape can serve as a makeshift solution. Overall, the placement of the quarter wave plate can influence the phase differences and the resulting image quality in microscopy.
hen
Hello everybody,
I would like to put a quarter wave plate in my microscope (between two
crossed polarizers).
In every book i saw so far, the plate was just before the upper
polarizer, and after the specimen.
my question is - can i put the plate before the specimen?
so the path will be : light source, polarizer, plate, specimen,
polarizer.
note: my specimen is birefringence object.
the way i see it, phase differences are added together, so is there a
problem?
Thanks!
Hanan.
My initial impression is no, it shouldn't matter.
Claude.
hen said:
Hello everybody,
polarizer.
problem?
Thanks!
Hanan.
Have you ever used a LASER to replace your light source, I did this years back when I had my old microscope, Images seem to be enhanced, but you have to make sure the LASER beam is set to an adjusted angle so the beam doesn't fully enter the lens array.
You have to be very careful or it can cause eye problems, I use to use the projector lens so I didn't have to look directly in the eye piece.
LASER light gives a much better luminous image.
it was a pocket LASER from a gift machine, had about a 1000ft range. cost me 50 cents to win.
never look directly at LASER light for fear of going blind. :smile:
I have a need for 2 things. One, I am told, does not exist: a broadband, zero-order, quaterwave plate (200 to 850nm) and the other is money to buy them.
If I can't buy it, I'd like to make it. Can anyone tell me whether I can make a quarterwave plate and if I can, is there a broadband version out there?
My goal is to allow a human eye to see circularly polarized light (without the aide of a camera).
A reasonably good retarder can be made with layers of cellophane tape becasue the tape is birefringent. Calibrate the tape by placing it between crossed polarizers.
A broadband zero-order quarterwave device exists- a Fresnel rhomb.
http://www.klccgo.com/
I can't help you with the money part.
hen said:
Hello everybody,
polarizer.
problem?
Thanks!
Hanan.
What are you trying to do? Putting the quarter wave plate prior to the speciment will simply illuminate the sample with (for example) circularly polarized light, depending on the orientation of the plate. Putting it after the specimen would be more interesting, I would expect.
DIC microscopy uses a pair of prisms rather than retarders, becasue it uses interference to increase the contrast.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
