lychette
- Messages
- 413
- Reaction score
- 73
The ions experience a force due to the electric field between the parallel plates...do you know how to calculate this?moenste said:Homework Statement
Hydrogen ions moving at various speeds are directed at a region of combined electric and magnetic fields as shown in the diagram below. The electric field is between two parallel plates 10 mm apart with a potential difference V across them, while the magnetic field of flux density 0.1 T is at right angles to the electric field.
(a) Calculate the value of V required so that ions of speed 100 m s-1 pass through the region of the two fields without being deviated.
(b) What is the kinetic energy per ion as they leave the combined fields?
(1 u = 1.67 * 10-27 kg.)
Answers: (a) 0.1 V, (b) 8.4 * 10-24 J.
2. The attempt at a solution
(a) Can't get it right. I use 0.5 m v2 = e V, where we don't know the mass m. I then tried to use F = B e v = 0.1 * 1.6 * 10-19 * 100 = 1.6 * 10-18 N and then F = m g so m = F / g = 1.6 * 10-18 / 10 = 1.6 * 10-19 kg -- not correct.
I also used B e v = m v2 / r so m = B e r / v = 0.1 * 1.6 * 10-19 * 0.01 / 100 = 1.6 * 10-24 kg. Also not correct.
I even thought that since we have hydrogen then its relative atomic mass is 1.008 and so 1.008 * 1.67 * 10-27 = 1.68 * 10-27 kg, also not correct.
If we plug in 0.1 V (which we need to find) into the first formula we'll get m = 3.2 * 10-24 kg. But I've got no idea how to find it.
They also experience a force due to the magnetic field...do you know how to calculate this
You seem to be going out of your way to avoid mentioning it. Perhaps you haven't been introduced to electric fields between parallel plates?
