How to Design a Variable Timed Circuit Cut Off?
  • Thread starter Thread starter GreasyBob
    Circuit Cut
To design a variable timed circuit cut-off activated by a push switch, a 555 timer circuit can be utilized. The circuit should be configured to operate within a timing range of 1-3 seconds for motor activation. Instead of using a relay, a power MOSFET should be employed to control the motor. Adjusting the size of the timing capacitor will help achieve the desired ON time. This setup is suitable for voltage ranges of 8.4 to 9.6 volts.
GreasyBob
im really drawing a blank on this one...
been a while since i done timers and its late!
im totally lost i need help designing a varible timed circuit cut off,
but it needs to be activated by a push to activate switch.
the timing on this literally needs to be 1-2 possibly even 3 seconds, to operate a motor,
and needs to be able to work time after time. its going to be running 8.4 to 9.6v
any help or pointing me in the right direction would really help
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
