What are p and q in relation to the given plane and vector?
  • Thread starter Thread starter joshwoods
    Plane Vector
The discussion focuses on calculating vectors p and q from the equation c = 10i + 2j - 3k, where p is parallel and q is perpendicular to the plane defined by 2x + 3y - z = 4. It is established that the dot product of p and q must equal zero due to their perpendicularity. The normal vector of the plane is identified as n = (2, 3, -1), which aids in determining the relationship between p and q. Confusion arises regarding the correct formulation of the vectors and the dot product calculations, indicating a need for clarification in the solution process. The conversation highlights the importance of correctly applying vector projections and the properties of dot products in vector calculations.
joshwoods
c = 10i+2j-3k = p + q
Calculate p and q where the vector p is parallel and q is perpendicular to the following plane:
2x+3y-z=4
a\bulletb= axbx+ayby+azbz
I know that because p is perpendicular to q the dot product between these two vectors should be zero. Also a vector parallel to the plane above is one which satisfies to equation of the plane and any vector perpendicular to the plane is a scalar multiple of the vector:
2x+3y-z
Good- though i would not write the vector as "2x+3y-z". You have already used x, y, and z as variables in the equation of the plane so it would better to use, say, i, j, and k as the unit vectors in the x, y, and z directions. That is, 2i+ 3j- k. Since 10i+2j-3k = p + q= p+ 2ai+ 3aj- ak, you can write p= (10- 2a)i+ (2- 3a)j+ (-1+ a)k. And, of course, because they are perpendicular, the dot product of p and q is 0: (10- 2a)(10)+ (2- 3a)(2)+ (-1+ a)(-1)= 0.
Solve that equation for a.
Hello,
Thanks for your help, I am still a little confused with the solution, when I solve for p I get:
p = (10-2a)i+(2-3a)j+(-3+a)k
but I am also confused about the dot product, should it not be:
q = 2ai+3aj-ak
pdotq = (10-2a)i(2a)i + (2-3a)j(3a)j + (-3+a)k(-a)k
This is what I get when I solve is out but my final answer still does not make sense. I must be making a small error at some point. It would be really great if you could help me out.
2x+3y-z=4
2x+3y-z
A vector lying in the plane does not satisfy the equation of the plane. The equation of the plane means that the difference between two vectors of the plane r and ro is perpendicular to the normal of the plane: (r-ro)n=0 which leads to the equation ax+bx+cz=C, where a,b,c, are the components of the normal and C is the dot product of ro with the normal vector.
The normal vector of the plane 2x+3y-z=4 is n=(2,3,-1), a vector, perpendicular to the plane. The vector c then is the sum of a vector, parallel to n and an other, perpendicular to n. You certainly know how to get the projection of a vector to a certain direction?
ehild
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
